HI MALC CAN YOU SPEND HOW TO INSTALL ON THE COCKPIT WIRE BAND SET ??? I DO NOT KNOW AS ITS INSTALLATION ...
maurizio67 wrote:HI MALC CAN YOU SPEND HOW TO INSTALL ON THE COCKPIT WIRE BAND SET ??? I DO NOT KNOW AS ITS INSTALLATION ... Hi Maurizio, I do not understand your question. Could you send a Picture please. Malc.
 If you can help me, I do not know how to install
Sorry for this question, I will try to understand it alone
maurizio67 wrote:Sorry for this question, I will try to understand it alone Hi Maurizio, No problem. I hope the "sketch" below helps. I formed the parts and then superglue to the body of the car. Malc. RM1 attached the following image(s):
Very good thank you Then the photo engraving is pasted
maurizio67 wrote:Very good thank you Then the photo engraving is pasted It's a pleasure.
RM1 wrote:And it includes the "Maflbero" decal set !!!! I malc, I use your topic build as references like the mfh boo to build my MP4/4. I have a question. This decals set that ave you posted is included with the DeAgostini pack? I've also bought the Autograph and MSM decals, but i have the fear to make some mistake for correct decal position. This kit is a template set to fit in right position the extra decals? I hope to explain me quite good. Thanks in advance. Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Hi Francesco,
I think you have two questions:
1. The Decal set that I posted was received with the last pack of parts. ( pack 20 )
2. I don't have a template guide to position the Autograph decals and had to use some guess work.
Wonderful build mate. I am in the middle of building mine ;)
May I ask where you got the FIA sticker on the Intake Plenum chamber and the stickers for the brake calipers?
I would love those as they look a real treat.
Thanks and Regards
Andre
monzaandre wrote:Wonderful build mate. I am in the middle of building mine ;)
Thanks and Regards
Andre Hi Andre, That FIA decal came on the Museum collection general sponser decal set. Also included are things like the brake caliper heat sensors and steering wheel stitching detail. Malc.
Roger that. Thanks Malcolm. Time to press the old order button ASAP :) Cheers Andre
RM1 wrote:The battery has one of it's connections standing vertically with no cable so I've added a cable and connector more or less as it appears in photos of the real thing. hello malc, where did you find the bar that holds the engine to the bottom dish? thank you
hello malc, where did you find the bar that holds the engine to the bottom dish? thank you[/quote] Hi Maurizio.
I think you mean the part arrowed in the picture below?
If so then this is the undertray support rod. I made it from a thin steel wire a ( 0.5mm I think ) and the triangular bracket was cut from 0.070mm steel shim stock and formed at the edges. The bolts were from a photo etch sheet of nuts and bolt heads. Hope that helps. Malc.RM1 attached the following image(s):
You would think you were looking at the real thing. A very nice model you have yourself there. Happy Modelling
RM1 wrote: hello malc, where did you find the bar that holds the engine to the bottom dish? thank you
Hi Maurizio.
If so then this is the undertray support rod. I made it from a thin steel wire a ( 0.5mm I think ) and the triangular bracket was cut from 0.070mm steel shim stock and formed at the edges. The bolts were from a photo etch sheet of nuts and bolt heads. Hope that helps. Malc.[/quote] thanks to malc, I meant that particular, now I understand how to do the piece
maurizio67 wrote:RM1 wrote: hello malc, where did you find the bar that holds the engine to the bottom dish? thank you
Hi Maurizio.
If so then this is the undertray support rod. I made it from a thin steel wire a ( 0.5mm I think ) and the triangular bracket was cut from 0.070mm steel shim stock and formed at the edges. The bolts were from a photo etch sheet of nuts and bolt heads. Hope that helps. Malc. thanks to malc, I meant that particular, now I understand how to do the piece[/quote] Glad to be of help  Here's the other view of it. Malc. RM1 attached the following image(s):
birdaj2 wrote:You would think you were looking at the real thing.
A very nice model you have yourself there. Thanks Tony. I appreciate your comments Malc.
hello malc, what pink dye did you use for the radiator tube? thanks in advance for your reply
maurizio67 wrote:hello malc, what pink dye did you use for the radiator tube? thanks in advance for your reply Hi Maurizio, I used a Tamiya Clear red ( X27 ) which I carefully sucked (by mouth) into the tube then sealed the ends. Hope that helps. Malc.
