17 Pages «<89101112>»
benny's build Options
benny
#181 Posted : 08 May 2011 20:30:12
hi all apart from a touch up and a couple of varnishes the deck is ready for the cannons to be rigged up,the cannon balls av been dipped in steel blackener and varnished
cheers benny
benny
#182 Posted : 08 May 2011 20:31:12
cheers benny
benny
#183 Posted : 08 May 2011 20:32:14
cheers benny
#184 Posted : 09 May 2011 09:00:02
Might be an idea to scrape the paint from the beam rest surface of the deck supports otherwise you may find that the beams won't adhere or break free.
benny
#185 Posted : 14 May 2011 13:00:06
hi all i have rigged a couple of cannons up,i found this very fiddly..i found some 2mm blocks in my old endeavour kit which i used instead of the supplied ones also i will need some longer pins to secure them to the deck as the ones supplied i felt were not long enough
cheers benny
benny
#186 Posted : 14 May 2011 13:03:54
im not sure if i am happy with this result i might redo
cheers benny
benny
#187 Posted : 15 May 2011 22:27:28
i wasnt happy with the cannon rigging so i have stripped them...must do betterBlink
cheers benny
tom.ganc
#188 Posted : 22 May 2011 18:57:40
Hi Benny
I've tried to use original stuff supplied by DeAgostini but I wasn't happy with the results, in the end I bought some more suitable (smaller) blocks and thread. You can check results in my build diary.
Can't wait to see new version of yours.
Tom
benny
#189 Posted : 22 May 2011 22:08:08
hi tom i have redone all 10 cannons but i have only fitted 5 ,the other 5 i will nail to the deck tomorrow.but i then realised that you will only see the backside of the cannons anyway.as long as there rigged then thats fine..sometimes i find myself being to fussy about parts of the build that dont need so much attentionBlink
cheers benny
farrabass
#190 Posted : 22 May 2011 23:27:27
Your cannons and rigging look good to me! I have also been contemplating improving the looks of the cannon, but as have you have decided that these particular peices are obscured I have come to a similar conclusion.
benny
#191 Posted : 27 May 2011 12:49:22
hi all i have finished one side of the cannons, rerigged and in my opinion slightly better. the odd end of rope i tied to another eyelet and fixed to the wall..the steps are in and stained..not far off finishing this deck now
cheers benny
Son of Bulwark
#192 Posted : 27 May 2011 15:36:41
Much better Benny! ThumpUp
It take a while to get the little thing's rigged. Nice job mate!
#193 Posted : 27 May 2011 17:11:06
The thing to remember is that its not a race, build at your own pace and take as long as you like and savour the end result!
benny
#194 Posted : 30 May 2011 21:01:51
hi all i have started the next deck i have completed the first 17 rows of decking and i will leave that to dry before finishing it off tomorrow
cheers benny
Son of Bulwark
#195 Posted : 30 May 2011 21:51:52
Hi Benny! Cool
Looks like you have a problem with photobucket mate, No Pictures!.
benny
#196 Posted : 30 May 2011 22:02:11
there showing on my pc...i will look into it
cheers benny
benny
#197 Posted : 30 May 2011 22:07:33
cheers darron i hope thats sorted now
cheers benny
Son of Bulwark
#198 Posted : 31 May 2011 16:13:46
Hi benny! Cool
Your picture problem is sorted and may I say it's looking good. Not much decking to do now then you can get on with all the detail work. Remember when you get to cutting the last ports and mainly the opening for the timber heads those top set of planks just want to snap.
She is taking shape! Keep up the good work mate.
benny
#199 Posted : 31 May 2011 18:12:27
thanks darron and cheers for the tip
cheers benny
farrabass
#200 Posted : 01 June 2011 12:27:44
Coming along very well!, just to repeat what Tomick said Don't rush.
Cheers Steve..
This page was generated in 0.137 seconds.
