 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
secured the bracket, and left hand lower brace. stevegbr attached the following image(s):
here is issue 27 stevegbr attached the following image(s):
here are the parts stevegbr attached the following image(s):
the caliper is attached to the disc and arm, then secured to the upper and lower wishbones. stevegbr attached the following image(s):
the shock absorber is assembled and secured with a pin and screw. stevegbr attached the following image(s):
here is issue 28 stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
the caliper is attached to the disc and arm, then secured to the upper and lower wishbones. the shock absorber is assembled and secured with a pin and screw. stevegbr attached the following image(s):
Making really nice progress Steve, well done.... Regards Alan
Glad to see you back on this steve  looks great  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
thanks alan and phil, nearly catched up now.
here is issue 29 stevegbr attached the following image(s):
putting the torsion bar on the sump cover. stevegbr attached the following image(s):
here is issue 30 stevegbr attached the following image(s):
the fan assembly, fitted fan to shaft, and fan motor to header tank. stevegbr attached the following image(s):
here is issue 31. stevegbr attached the following image(s):
header tank fitted to chassis, and front sub frame, left and right mounting flange fitted to chassis stevegbr attached the following image(s):
Guest (5)
