6 Pages <1234>»
Artesania 1/16 Fokker Dr.1 Build Options
#21 Posted : 28 October 2017 19:52:01
Hi coming along at a fair rate.do like these skeleton kits.must try one sometime.doing a great job.cheers mick.BigGrin
#22 Posted : 29 October 2017 19:58:41
BigGrin Thanks for looking in and your comments MickCool
#23 Posted : 29 October 2017 20:17:49
BigGrin Hi All
More progress, the rear cockpit divider plate, floor, cockpit seat,seatbelts,joystick,various instruments,rudder pedals and leather bag have all been fitted to the fuselage. The wood floor and seat were painted using the AL Wood Grain Painting Mask I would recommend practicing with the mask 1st if you want a good finish.
Next you add the rudder and elevator control cables then the bracing wires and turnbuckles to the rear of the fuselage are added, I nearly have all of them in position now. When fitting the bracing wires no need to make them bar tight as after the glue has set you can use a heat gun the shrink them tight as the wire is made of a heat shrink material.
More soon.
#24 Posted : 29 October 2017 22:18:12
That`s looking fine Andy.
Superb detail.
Cool Cool Cool Cool
#25 Posted : 29 October 2017 22:25:02
Looking great AndyBigGrin AL have really put some thought into this kit, great idea to use heat shrink material.
#26 Posted : 30 October 2017 20:42:38
BigGrin Thanks for looking in and your comments ladsCool
#27 Posted : 01 November 2017 17:56:37
Looks like a great kit you have there Andy!Cool Top work so far!BigGrin
#28 Posted : 01 November 2017 18:28:46
BigGrin Thanks for looking in Phil and your commentsCool
#29 Posted : 02 November 2017 20:09:06
BigGrin Hi All
Small update, the bracing wires are all done and the tailplane added to the fuselage. If your going to build this the mounting pegs on the fuselage will need to adjusted/reduced in diameter so the tail/elevator section sits correctly on the fuselage.
After the tailplane was fitted the two braces were added then the control wires from the joystick were connected. Lastly the rudder was fixed in position with two brackets and brass pins then the control cables were added.
Note.
I used a heat gun designed to shrink R/C model aircraft covering to shrink the heat shrink wires. Just be careful when doing an overall shrink on the fuselage. Link below to the heat gun I used:-
https://www.towerhobbies...?&I=LXHZ16&P=ML
More soon.
#30 Posted : 03 November 2017 00:02:38
Looking good Andy, really nice progress....Cool Cool
#31 Posted : 03 November 2017 11:12:58
Really coming along now AndyBigGrin looks superbDrool regards PhilCool
#32 Posted : 03 November 2017 13:01:09
Looking great Andy, really nice work with all those bracing wires.
#33 Posted : 03 November 2017 19:06:30
Really nice work Andy, you’ve certainly cracked on with this. Those bracing wires look fiddly. Great work ThumpUp
#34 Posted : 03 November 2017 19:19:52
#35 Posted : 03 November 2017 20:04:49
Those bracing wires look fun. Crying Blink Blink
Really looking the part now though.
WTG
#36 Posted : 04 November 2017 19:13:12
BigGrin Thanks for looking in Derek and your commentsCool
#37 Posted : 04 November 2017 19:32:19
BigGrin Hi All
The ammo boxes were made up and painted along with the oil tanks and fuel tank.
The large oil tanks are due to the engines lubrication system which was a throw away system. The castor oil was mixed with the fuel through the carburreta then it passed through the cylinders and was ejected out of the exhaust ports and hence the oily faces of the pilots from the spray back who flew these machines.
The next thing to be added is the aileron cables once done the engine firewall was made up with the carburreta and mount added to the rear. The fire wall is added to the fuselage using 4 long bolts and nuts. Then the carburreta T piece that exits on either side of the fuselage went on.
The last part added was the fuel tank.
More soon.
#38 Posted : 05 November 2017 00:05:16
This is looking great and really gives you an insight of how they were put together, nicely done Andy Cool
#39 Posted : 05 November 2017 10:42:17
Really great build, this is definitely a show piece model.
#40 Posted : 05 November 2017 19:14:17
Hi Andy, coming along at fair pace ,looking great.cheers Mick.BigGrin
6 Pages <1234>»
