7 Pages <1234>»
Dave71 Yamato Options
#21 Posted : 02 November 2017 09:16:06
Dave
Very neat planking work and you are getting through that part at a pace.
Hope it all continues well for you.
#22 Posted : 02 November 2017 12:00:49
Great job on the planking, good to see her taking shape.
#23 Posted : 02 November 2017 12:32:12
Nice work Dave BigGrin she's looking good.
#24 Posted : 02 November 2017 13:28:49
Progressing really well DaveBigGrin great stuffCool regards PhilCool
#25 Posted : 02 November 2017 13:32:49
SAhe's taking shape more now, excellent work.
Dave 71
#26 Posted : 02 November 2017 19:20:58
Thanks for all your comments it really appreciated hope to spend the day in the man cave tomorrow finishing off the port side and starting the starboard. Off work this work
#27 Posted : 02 November 2017 19:55:13
BigGrin Looking good, you will soon be fitting the armour beltsCool
Dave 71
#28 Posted : 04 November 2017 16:51:33
I'M STUCK , can some one show me a clear picture of the sturn from frame 12 to 14 please see picture as not sure how to do this bit as picture,s in PDF isn't very clear when you try to enlarge.
Dave 71 attached the following image(s):
#29 Posted : 04 November 2017 18:23:31
BigGrin Hi Dave
If you look at my build diary page 3, post #50 onward you can see how I did mine:-
http://forum.model-space...osts&t=2756&p=3
Did the kit come with some triangular balsa as this is used to act as a filler between the planks and the armour strip.
Dave 71
#30 Posted : 04 November 2017 19:46:12
Thanks Andy, didn't won't to do it wrong,it's good to no there's a lot of surport when you need it and to answer your question I've not found any triangular pieces yet will double check.
Dave 71
#31 Posted : 05 November 2017 17:52:39
Had to undo some of the hard work I'd spent doing over the weekend as I'd used the wrong stakes. That will teach me to read the instructions properly
Andy point out there should be some triangular stakes witch I found after I'd just about finished one side of the boat. Any way after undoing it all I've manage to put in right now, see picture's.
#32 Posted : 05 November 2017 18:11:04
And very nicely done Dave.
Its not easy having to take apart something you have already put together but if you had not mentioned it you would never have guessed.
Credit to you on the planking because you have managed a very nice looking hull in a very fast time.
Dave 71
#33 Posted : 05 November 2017 20:40:29
Thank,s Tony ,be leave you me it wasn't easy to put it right but I daresay
I won't be the first or the last to make a mistake and there'll probably be more mistake to come but if there,s one thing I have learnt it,s to ( read the instructions properly.)
#34 Posted : 05 November 2017 21:40:39
BigGrin Plankings looking good and glad you got the hick-up sorted out she's back on track now, nice workCool
#35 Posted : 06 November 2017 22:29:02
Very nice planking, look forward to more updates.
Chris Cool
#36 Posted : 07 November 2017 12:11:33
Glad you sorted it DaveBigGrin looks greatDrool regards PhilCool
#37 Posted : 07 November 2017 14:20:51
Looks great Dave BigGrin pleased you got it sorted.
#38 Posted : 07 November 2017 15:57:27
Great job on the planking, looking good.
Dave 71
#39 Posted : 19 November 2017 00:20:33
All the planking is now done on the side of the Hull. So now concentrating on some of the metal work starting with the base.will post some picture,s when there's some thing done .
#40 Posted : 19 November 2017 01:01:04
BigGrin Hi Dave
Glad your progressing well, Just a word of warning on the metal parts the sides are not square on the base so assemble on a flat surface with epoxy and then use car filler on the top surface to get a good flat base for the rest of the superstructure to sit on.
7 Pages <1234>»
