 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
ht leads are pushed in to distributor and plug caps pushed in to engine head. stevegbr attached the following image(s):
here is issue 16. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
put the door handle on with one screw. stevegbr attached the following image(s):
here is issue 17. stevegbr attached the following image(s):
screw the window to the door. stevegbr attached the following image(s):
attach the door hinge. stevegbr attached the following image(s):
here is issue 18. stevegbr attached the following image(s):
secure the door panel. stevegbr attached the following image(s):
attach the arm rest, door handle and window winder. stevegbr attached the following image(s):
press the door card in place, and attach the trim. stevegbr attached the following image(s):
Wow Steve, you're certainly not hanging around in putting this together and its great to see.... all looks good, well done..... Regards Alan
Looking very nice, good work.
Some speedy progress Steve  looks great, good to see your back on the Jag. Al
thanks guys, she will be a beauty.
Nice work Steve, she's looking good. Mark Regards Markwarren (Mark) Admin
cheers mark, be doing a few more later..
