13 Pages «<34567>»
Stevegbr E-type Jaguar Build. Options
stevegbr
#81 Posted : 01 November 2017 23:18:01
here is issue 12.
stevegbr
#82 Posted : 01 November 2017 23:18:33
here are the parts.
stevegbr
#83 Posted : 01 November 2017 23:26:42
attaching the starter motor,distributor,and the carburettor assembly attached to the engine block.
stevegbr
#84 Posted : 01 November 2017 23:28:37
here is issue 13.
stevegbr
#85 Posted : 01 November 2017 23:41:42
here are the parts.
stevegbr
#86 Posted : 01 November 2017 23:44:18
fitted the filter head and hose.
stevegbr
#87 Posted : 01 November 2017 23:46:08
fitted the battery box in to the engine block.
stevegbr
#88 Posted : 01 November 2017 23:47:46
here is issue 14.
stevegbr
#89 Posted : 01 November 2017 23:49:29
here are the parts.
stevegbr
#90 Posted : 01 November 2017 23:54:48
assembled the ignition lead and coil. secured to the engine block, and engine breather fitted.
stevegbr
#91 Posted : 01 November 2017 23:57:32
fan belt and pulleys fitted to timing case cover.
stevegbr
#92 Posted : 02 November 2017 00:00:44
dynamo is fitted with end cap.
stevegbr
#93 Posted : 02 November 2017 00:03:12
large pulley fitted to fan belt.
stevegbr
#94 Posted : 02 November 2017 00:04:43
here is issue 15.
stevegbr
#95 Posted : 02 November 2017 00:05:26
here are the parts.
stevegbr
#96 Posted : 02 November 2017 00:08:17
exhaust manifolds fitted to engine block.
stevegbr
#97 Posted : 02 November 2017 00:11:21
fitted the rev counter generator in the end of cam cover.
stevegbr
#98 Posted : 02 November 2017 00:13:18
cylinder head fitted to left hand engine block.
stevegbr
#99 Posted : 02 November 2017 00:16:05
timing cover and right hand side block secure the engine together.
stevegbr
#100 Posted : 02 November 2017 00:17:56
coil lead is pushed in to distributor.
Guest (8)
13 Pages «<34567>»
This page was generated in 0.436 seconds.
