 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
place the handle on the door which is held by a screw. stevegbr attached the following image(s):
here is issue 7. stevegbr attached the following image(s):
here are the parts. stevegbr attached the following image(s):
putting the door hinge on the door. and door glass. stevegbr attached the following image(s):
here is issue 8. stevegbr attached the following image(s):
putting the inside door panel, held by four screws. the arm rest i relised i put it upside down, which as been corrected. and put the door handle and window handle on. and secured the door card. stevegbr attached the following image(s):
here is issue 9. stevegbr attached the following image(s):
the seat cushion is pressed in place. stevegbr attached the following image(s):
here is issue 10. stevegbr attached the following image(s):
the throttle linkage and shaft attached to the manifold. stevegbr attached the following image(s):
here is issue 11. stevegbr attached the following image(s):
press the two halves of the manifold together. stevegbr attached the following image(s):
three suction chambers are attached. stevegbr attached the following image(s):
petrol pipe is put in place. stevegbr attached the following image(s):
air balance pipe is attached. stevegbr attached the following image(s):
the air cleaner is now fitted. stevegbr attached the following image(s):
Guest (6)
