13 Pages «<23456>»
Stevegbr E-type Jaguar Build. Options
stevegbr
#61 Posted : 01 November 2017 22:22:44
place the handle on the door which is held by a screw.
stevegbr
#62 Posted : 01 November 2017 22:24:15
here is issue 7.
stevegbr
#63 Posted : 01 November 2017 22:24:49
here are the parts.
stevegbr
#64 Posted : 01 November 2017 22:28:31
putting the door hinge on the door. and door glass.
stevegbr
#65 Posted : 01 November 2017 22:30:15
here is issue 8.
stevegbr
#66 Posted : 01 November 2017 22:31:41
here are the parts.
stevegbr
#67 Posted : 01 November 2017 22:44:06
putting the inside door panel, held by four screws.
the arm rest i relised i put it upside down, which as been corrected.
and put the door handle and window handle on.
and secured the door card.
stevegbr
#68 Posted : 01 November 2017 22:47:04
here is issue 9.
stevegbr
#69 Posted : 01 November 2017 22:48:30
here are the parts.
stevegbr
#70 Posted : 01 November 2017 22:50:15
the seat cushion is pressed in place.
stevegbr
#71 Posted : 01 November 2017 22:52:49
here is issue 10.
stevegbr
#72 Posted : 01 November 2017 22:53:38
here are the parts.
stevegbr
#73 Posted : 01 November 2017 22:59:50
the throttle linkage and shaft attached to the manifold.
stevegbr
#74 Posted : 01 November 2017 23:01:34
here is issue 11.
stevegbr
#75 Posted : 01 November 2017 23:03:58
here are the parts.
stevegbr
#76 Posted : 01 November 2017 23:07:24
press the two halves of the manifold together.
stevegbr
#77 Posted : 01 November 2017 23:09:13
three suction chambers are attached.
stevegbr
#78 Posted : 01 November 2017 23:11:35
petrol pipe is put in place.
stevegbr
#79 Posted : 01 November 2017 23:14:05
air balance pipe is attached.
stevegbr
#80 Posted : 01 November 2017 23:16:12
the air cleaner is now fitted.
13 Pages «<23456>»
This page was generated in 0.317 seconds.
