A closer look than the previous pictures of the more or less finished front end. ( the camera really highlights the imperfections....must clean up that paint a little )RM1 attached the following image(s):
Beautiful work Malc, really coming along..... Regards Alan
Thanks, guys, for the kind comments.
Help needed !I've reached the stage where I'm planning to fit the screen to the body panel. It comes as a vacuum formed piece that needs to be cut out along lines which are formed in the moulding. I guess a sharp scalpel and lots of care but does anyone have any advice or tricks that can make this process a little easier? Thanks in advance. Malc. RM1 attached the following image(s):
Just had to see how it looks with the nosecone in place. Not much cleaning up needed to get these parts fitting. Malc.RM1 attached the following image(s):
On to the next little collection of castings !RM1 attached the following image(s):
It all came together quite nicely. I've added some cabling for a bit of extra detail.RM1 attached the following image(s):
The panel locates across the cockpit sides.RM1 attached the following image(s):
Nearly finished the safety harness as well. RM1 attached the following image(s):
Progress on the Roll-over bar. The diecast parts polish up nicely. RM1 attached the following image(s):
Head restraint bars added. Quite tricky to form from rod. No HANS device or Halo in those days ! RM1 attached the following image(s):
That really is looking a beauty, excellent wok. Mark Regards Markwarren (Mark) Admin
 Nice work Malc, the chromed metal parts MFH do polishes up very well Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for looking in guys. Malc.
Time to get cracking on the DFV ! RM1 attached the following image(s):
Some great detail on these diecast parts. Even the pistons look properly timed. Pity it all gets hidden.RM1 attached the following image(s):
This is looking great. Loads of detail and well built. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 That engine will look sweet cant wait to see the results Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Guest (6)
