106 Pages «<7172737475>»
#1441 Posted : 27 October 2017 21:27:38
Great work with the paint job, looking superb.
#1442 Posted : 30 October 2017 10:22:07
Thanks very much Graeme!Cool
#1443 Posted : 30 October 2017 10:37:17
Phil
Love the painting.
Shame you have run out of paint but sure you will soon resolve that and be able to press on.
All those upgrades you have made to your build all blend in very well under the paint layer.
Hope it all continues well.
#1444 Posted : 30 October 2017 11:21:23
birdaj2 wrote:
Phil
Love the painting.
Thank you Tony!Cool I ordered more paint last Friday and managed to get a couple more coats on the lower hull during the weekend aswell as carry out some running repairs. One more final coat tonight, then varnish and that should be it!
#1445 Posted : 02 November 2017 21:40:24
Good evening from 'The Dockyard',
This weeks update of my U230 U-boat build sees the lower hull sprayed in the dark grey after restocking and painting in the draught marks.
Although it wasn't as straight forward as that!Blink
After the lower hull was sprayed I began to peel back the masking tape with trepidation, expecting to see loads of over spray only to find there was a minimal amount. In fact the opposite of over spray. No paint at all! In some areas the masking tape took with it some of the paint, even after a liberal coat of varnish, but also a few rivets here and there!
So, to summarise, I've spent all this week applying rivets and painting in by hand all the areas affected. I must admit that rather than get frustrated at the situation, it kind of worked in favour, as where I had touched up with paint, it looked more realistic.BigGrin
The attached photo shows the dark, medium and light grey areas on the starboard bow.
#1446 Posted : 02 November 2017 21:41:38
Looking aft, along the starboard side.
#1447 Posted : 02 November 2017 21:42:11
Starboard aft view.
#1448 Posted : 02 November 2017 21:42:47
Full, starboard side view.
#1449 Posted : 02 November 2017 21:46:20
The attached photo shows the port aft draught marks. I had already painted in the bow and amidships draught marks.
A little tricky as where I had fixed the numbers with a liberal coat of superglue, meant the outline of the numbers was slightly less defined. To be honest, I would rather they remained fixed in place than have one of them get knocked off at a later stage.
#1450 Posted : 02 November 2017 21:48:07
Starboard bow draught marks.
#1451 Posted : 02 November 2017 21:48:46
Starboard aft draught marks.
#1452 Posted : 02 November 2017 21:51:23
Looking forward along the starboard side.
#1453 Posted : 02 November 2017 21:57:12
Well that concludes this weeks short update.
The next stage, which I have changed my mind several times on regarding the sequence of painting, will see the compartments sprayed in off-white [ivory white], as per the part-works.
I think some of them had split colours with a light grey on the lower half, but I will have to check this. For now though, an even coverage of ivory white will make for a start.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
#1454 Posted : 02 November 2017 22:31:26
Phil
I really do like the colour scheme you have used. Makes it much more eye catching than an overall monotone dark colour.
hope your weekend goes well also.
#1455 Posted : 02 November 2017 22:49:45
birdaj2 wrote:
Phil
Thanks Tony!Cool I particularly like the camouflage stripes; they add that bit extra, which is one of the reasons I chose this boat.
See attached photo of U230 in La Spezia, 1943. [used with permission]
daffy09
#1456 Posted : 02 November 2017 23:48:49
Hi Phil
It's a real treat to the eye to see her in her colours. And I agree with Tony that the camo effect you've chosen is much more interesting. Looking forward to your next update
Happy building
David
#1457 Posted : 03 November 2017 00:12:46
Beautiful, she just gets better and better....Cool Cool
#1458 Posted : 03 November 2017 10:42:25
daffy09 wrote:
Hi Phil
Happy building
David
Thanks for looking in David!Cool Glad you like the colour scheme.BigGrin
#1459 Posted : 03 November 2017 10:43:19
Thank you Alan and very nice of you to say so!Cool
Phil W.BigGrin
#1460 Posted : 03 November 2017 11:10:50
Turned out great PhilDrool when you weather it all those rivets should pop out beautifullyCool regards PhilCool
Guest (15)
This page was generated in 0.473 seconds.
