38 Pages «<45678>»
Garth's Black Pearl Options
#101 Posted : 24 October 2017 11:27:27
Great work Garth, Barrells look excellent.ThumpUp
#102 Posted : 26 October 2017 11:28:51
Hi Garth.
Very nice work with the air brush.
IanCool BigGrin
#103 Posted : 30 October 2017 06:19:47
Hi Alan, Tony, Mark and Ian.
Thank you for looking in and for the kind words.
#104 Posted : 30 October 2017 06:47:18
Hi All,
I Started preparing the hull for lighting.
The LED’s for the lanterns will each require a resistor. It will be possible to make a small pc board and hide it behind the aft bulkhead, but I did not relish the idea of running (and keeping track of the polarity of all those tiny wires).
To simplify this, I stripped down some household wire and made two ‘Buzz Bars’ to connect the lanterns and resistors. It is about Ø1mm. I then cut slots into the top of the bulkheads to accommodate the wires. Once the wires were Superglued into the slots, I replaced a small piece of insulation on the ends – this indicates the polarity. I then soldered on the resistor opposite each lantern.
Next will be wiring the LED’s and making the lanterns.
#105 Posted : 30 October 2017 09:06:20
Nicely done Garth, will be interesting to see how it all turns out....Cool Cool
#106 Posted : 30 October 2017 14:25:58
Nice work Garth, look forward to seeing them working.
MarkBigGrin
#107 Posted : 30 October 2017 16:12:08
Nice idea to have some lights in there.
Hope it all goes to plan for you.
Bazholding
#108 Posted : 30 October 2017 20:06:28
I like the idea of a bus bar, will be interesting to see how it turns out
Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
#109 Posted : 31 October 2017 06:41:52
Hi Guys,
Thanks for looking in.
The lanterns are coming on, but the armature wire is not working as hoped.Cursing
I will post some pics when I have installed them all.
#110 Posted : 01 November 2017 11:21:49
Hi Garth, hope you get it sorted!Cool
#111 Posted : 06 November 2017 06:43:15
Hi Phil,
Thank you for looking in. Lanterns are done, not 100% happy, but it will do.
#112 Posted : 06 November 2017 06:46:34
Hi All,
Finally the lower deck lanterns are fitted. Below is my description, please bear in mind that this is a work in progress and I think that my method requires some fine tuning.
I decided to light the lanterns using surface mounted LED’s. They fit comfortably inside the lanterns body. Unfortunately, I have used up all my thin wire that I used on the Victory’s lanterns and have had to use Armature wire instead.
The coating on the wire is extremely tough and has to be removed in order for the solder to stick. To do this, apply an open flame to the tip of the wire and the insulation burns away. Trim the end and apply the solder.
I stuck the LED’s to a piece of scrap styrene with double sided tape to hold them and tinned the ends. Hold the tinned end of the wire to the led and touch the soldering iron tip to the joint. Note: I cut one wire slightly shorter and soldered this to the Negative side of the LED. This just helps with the keeping track of the polarity during the installation.
I assembled the lantern bodies according to the instructions with the following exceptions: I used solder rather than superglue, I drilled a Ø1mm hole in the corner of the top for the wires and I decided not to fit the bottom plate, just to help spread the light.
Once the all the assemblies were complete, applied a small blob of silicone sealer and ‘glued’ the LED’s in place. This needs about 6 hours to dry.
Next I fitted the lanterns and soldered the wires to the ‘Buzz Bars’. Once all was installed I painted the wires matt black.
In hindsight:
The Armature wire is really hard to work with – I must find a suitable alternative.
If you follow my method – test the assemblies after every step, especially before the final solder. Its soul wrenching to have to remove a fitted lantern and trouble-shoot the connections.
I have noticed that some of the lanterns flicker when the model is bumped, but after spending about 14 hours on them, I really don’t feel like going back. Perhaps there will be some dead lanterns once the hull is complete; I’m just going to have to live with that!!!
#113 Posted : 06 November 2017 10:26:53
Credit to your patience with this one Garth.
Had not realised you were putting the leds into the lanterns and they are so small.
I think you have done a great job on these and they will look fantastic once that section of your build is complete.
#114 Posted : 06 November 2017 10:56:41
Really inspiring piece of work Garth, those lanterns look fab.....Drool Drool
#115 Posted : 06 November 2017 12:00:07
Patients of a saint. Those lanterns look terrific.
daffy09
#116 Posted : 06 November 2017 12:09:09
Fantastic work Garth, those lanterns are a masterpiece. Your soldering skills are really showing their worth now. Just a quick question. Did you use coloured LED's, or did you lower the luminosity of them with the resistors?
Well done that man
Happy building
David
#117 Posted : 06 November 2017 12:30:37
Hi Tony, Alan Mark & David,
Thank you for looking in and for the kind remarks.
David. Sorry, I should have mentioned in the beginning, the Surface Mounted LED's are yellow with a 840Ω resistor and a 12v DC Power supply.
#118 Posted : 06 November 2017 15:28:23
Hi Garth.
Great job on the lighting.
looks fantastic.
Ian Cool BigGrin
#119 Posted : 06 November 2017 15:31:26
The lanterns look superb, great job.
#120 Posted : 06 November 2017 19:42:26
Excellent work on the lanterns.
Cool Love Cool Love Cool
Can only make for a superior finish to your model. WTG
38 Pages «<45678>»
This page was generated in 0.218 seconds.
