5 Pages <12345>
Graeme's Akagi build Options
#41 Posted : 15 April 2017 08:37:00
That is looking all very nice and neat. Hope it continues to go well for you.
#42 Posted : 05 October 2017 09:35:12
I have finally got back to doing some more work on this. I have now completed the hull planking - still needs filling and sanding - and have fitted the stern frames. I have also fitted (but not glued) the bow hanger floor.
I am now awaiting delivery of some epoxy resin which I will use to coat the inside of the planking to strengthen it before sanding the outside to shape.
#43 Posted : 05 October 2017 09:39:31
Great to see you back on herBigGrin nice job on the plankingDrool regards PhilCool
#44 Posted : 05 October 2017 12:14:15
Looking good Graeme BigGrin
#45 Posted : 05 October 2017 13:04:37
Nice work Greame, Coming on very nicely.
#46 Posted : 05 October 2017 16:21:19
BigGrin Hi Graeme, looking good another tip at this stage is to put all the lift machinery in place inside the lift boxes before glueing them in place on the hullCool
#47 Posted : 05 October 2017 18:41:59
Thanks for looking in guys.
Thanks for he heads up Andy, I will take note of that.
#48 Posted : 05 October 2017 19:36:12
Doing a great job Graeme, great to see an update on this one...Cool Cool
#49 Posted : 09 October 2017 14:27:15
That`s a fine looking start and nice progression with the planking. Drool
Also congrats on your "Purple medal for 1000 posts.
Cool Cool Cool Cool
#50 Posted : 10 October 2017 13:31:12
Derek,Alan - thanks for looking in.
Just a brief update - the epoxy arrive and the inside of the hull was duly coated and left to dry for 24 hrs. The central hanger floor was then fitted (not glued) and the stern block glued in place.
The next job is to mark out and fare the underside of the hull.
#51 Posted : 10 October 2017 14:12:09
Coming along great GraemeBigGrin i can smell the epoxy from here Laugh regards PhilCool
#52 Posted : 12 October 2017 07:53:20
Great to see you back at your AKAGI!
I will be following with interest as i got her on the shelf as well.
#53 Posted : 24 October 2017 11:16:20
I have temporally fitted all the hanger floors, Pic 1, and marked and sanded the curves at the bottom of the hull. I then roughly sanded down all the planking and removed most of the steps between the bow/stern blocks and the planking, Pics 2, 3 & 4.
I then applied filler to the worst areas of the hull, Pic 5, followed by sanding this down and then applying an initial coat of primer to show up the areas that still needed more work (plenty of them). The primer was then sanded back to show these areas more clearly, Pic 6.
After reading through the instructions for the next few issues – which had you applying the prop shaft A frames and bilge keels – I decided I would veer from said instructions and finish off the hull first as I was certain these fittings would not survive further sanding of the hull.
I have, therefore, started to shaped and fit the armour belt extension pieces, Pic 7. The step in the planking at the bow was first cleaned up, Pic 8, and the forward two pieces of the armour test fitted in place, Pic9. These pieces were then glued in place, Pic 10.
After reading Andy’s (ARPurchase) build diary and checking my Akagi plans, the stern armour belt was extended by 44mm, taking it to just short of the stern block, Pic 11.
Now as far as the hull goes it is a case of sand/fill/sand etc. until I am happy with the shape and finish.
I will start to assemble the hangers between sanding sessions.
That’s it for now
#54 Posted : 24 October 2017 11:22:17
lovely work Graeme, coming on very well.ThumpUp
#55 Posted : 24 October 2017 11:34:40
Really coming along GraemeBigGrin great job on filling,sanding and belt armour Drool Drool regards PhilCool
#56 Posted : 24 October 2017 17:57:07
BigGrin Looking great Graeme and nice workCool
#57 Posted : 24 October 2017 18:41:26
Very nice work Graeme Cool
#58 Posted : 24 October 2017 23:04:09
Lovely progress Graeme, doing a great job....Cool Cool
#59 Posted : 25 October 2017 06:44:11
I`m afraid i can only see a few of the pics (most of them won`t Show up) - but the ones i see look great!
This is about the point i put my AKAGI aside to finish the Vic first - so i`will be following with great interest as this build moves along!
#60 Posted : 25 October 2017 09:03:06
Thanks for the interest guys, much appreciated.
Just a brief update.
I have progressed to building the main bow hanger and the port bow hanger, (waiting for the weekend to do any more on the hull so I can hopefully get outside in daylight to do the sanding).
Pic 1 shows the main bow hanger framework assembled. The rounded end is clad with planking strips laid vertically and the sides with sheet material. Pic 2 shows the cladding in progress.
Pic 3 shows the main hanger completely clad, but not sanded, together with the completed frame of the port hanger. The curved side of the port hanger is then clad in a strip of very thin and flexible wood and pic 4 shows the completed hangers after sanding – a little filler was needed along some of the joints between the planks on the curved bow section.
5 Pages <12345>
