Partial obstructed opening on fore gun deck Options
m0325
#1 Posted : 21 October 2017 22:14:22
The round opening for for mast on fore gun deck is partially blocked by the underlying beam on form 2 on which it sits. Is the partial obstructiion by the underlying beam to be removed with a file via the opening (5J).
#2 Posted : 21 October 2017 22:31:30
Instructions page 30 in pack 2 tells you to clear the hole using a file.
Hope that helps.
m0325
#3 Posted : 22 October 2017 18:24:32
Tony: Thanks for the reply. That means that the underlying beam that is glued to and supports that deck will essentially be severed by removing it with a file.
#4 Posted : 22 October 2017 18:49:05
The beam is glued to the deck you fit on top but yes you are right in that when you get to this stage the beam is almost cut through.
I am still to glue in my top decks but looking at mine it appears over half of the beams width will be filed away.
#5 Posted : 22 October 2017 21:00:57
Hi m0325
Its perfectly ok to file through the beam as it was there to support the deck panel as the glue was drying. The deck has plenty of support from the other beams added on either side.
Hope this helps.
m0325
#6 Posted : 22 October 2017 23:05:52
Tony and Andy: Thank you. It is clear now. Lucky to help.
This page was generated in 1.500 seconds.
