Beautiful work as always Alan, great jb.
Such a beautiful build, Alan!Greetings, Walter
Lovely craftsmanship Alan  superb work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks guys, appreciate all those who looked in and commented....  .. Regards Alan
Lovely work Alan, could easily pass for a full size boat sitting in a boat builders' shed!
Very nice indeed, well done.
Kev
Really nice job with this Alan
Dave/Kev, thanks for looking in and the kind comments... Always appreciated... Regards Alan
The finish line is now very much in sight... Continued with marking out the water line and to start the painting of the lower hull.. Gave everything a fine sanding down, masked and covered everything above the water line. At this point I applied a coat of matt varnish along the edge of the masking tape, the last thing I wanted to see was any paint bleed under the tape..... Once happy I then spayed the lower hull with two coats of primer, sanding down again between coats. This was left to dry for 24 hrs, gave it another fine sanding before applying 2 coats of top coat, an off white was used and again a light sanding was given between coats.... Left to dry and harden fully before moving onto gluing into place all of the fixtures that were previously made up. Finally the rudder was fitted....  .. Only thing left now is to make up the 16 oars and the build stand. These are all made from scratch, nothing is prefabricated and each oar consists of 5 separate elements. Will cover the construction in the next update...  .. Until next time, happy modelling..... Regards Alan Gandale attached the following image(s):
 Rank: Pro  Groups: Registered
Joined: 26/01/2014 Posts: 119 Points: 343 Location: Newcastle
very nice. well done Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
Absolutely stunning  work Alan, a real credit to the skills you have. The detail is amazing mate. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Baz/Chris, thanks for looking in and your kind comments.... appreciated... Regards Alan
Perfect work. Seems a shame to paint it.
z8000783 wrote:Perfect work. Seems a shame to paint it.
Thanks John, appreciated..... Agree with you but this is being done as an OOB build, very little painting of the kit apart from the lower hull....  .. Regards Alan
Fabulous!! Simply Fabulous Alan no doubt about it..  Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Superb workmanship Alan  a credit to you. Al
She is absolutely superb Alan  great skill you have  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
 Very nice work and a credit to you Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Stunning work Alan Happy building David
An absolutely stunning build Alan, she's looking amazing.
WTG Alan, A masterpiece. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
