Diecast parts Options
carlton
#1 Posted : 16 October 2017 18:37:33
Rank: Beginner Level 3
Did not like the seam on the die cast part , cleaned up the seams the paint and polished the part , looks good natural . Has anyone consider die cast parts with no paint ?
#2 Posted : 17 October 2017 08:20:56
Most of the diecast parts are clad within a plastic shell and therefore won’t be visible.
Perhaps post a few photos of what you’ve done?
carlton
#3 Posted : 17 October 2017 23:05:19
Sorry cant upload pixs for some reason. Going to try and repaint see how it goes.
#4 Posted : 18 October 2017 07:24:27
Hi Carton, if you look at the R2 custom build page, you will see I have painted some metal parts after taking the seams off. I also show what paint I used if that helps.
carlton
#5 Posted : 18 October 2017 16:07:55
Thanks for the input Markwarren and Tomick , was having problem with primer and paint sticking to the metal surface. I like the real metal look but it was not that way in all the movie props I've looked at . Found out I needed to etch the metal surface with vinegar and water , so attempt number three .
#6 Posted : 18 October 2017 16:38:18
I use rustoleum self etching primer when I paint metal parts.If you use enamel paint you can also put the parts into a food dehydrator.This cures the enamel paint much quicker and gives you a very strong and tough paint finish.I do this with all my 1/43 metal car bodies.
