 Rank: Beginner Level 3  Groups: Registered
Joined: 13/06/2017 Posts: 26 Points: 71 Location: Texas
Did not like the seam on the die cast part , cleaned up the seams the paint and polished the part , looks good natural . Has anyone consider die cast parts with no paint ?
Most of the diecast parts are clad within a plastic shell and therefore won’t be visible.
Perhaps post a few photos of what you’ve done?
Sorry cant upload pixs for some reason. Going to try and repaint see how it goes.
Hi Carton, if you look at the R2 custom build page, you will see I have painted some metal parts after taking the seams off. I also show what paint I used if that helps. Regards Mark Regards Markwarren (Mark) Admin
Thanks for the input Markwarren and Tomick , was having problem with primer and paint sticking to the metal surface. I like the real metal look but it was not that way in all the movie props I've looked at . Found out I needed to etch the metal surface with vinegar and water , so attempt number three .
I use rustoleum self etching primer when I paint metal parts.If you use enamel paint you can also put the parts into a food dehydrator.This cures the enamel paint much quicker and gives you a very strong and tough paint finish.I do this with all my 1/43 metal car bodies.
