8 Pages «<5678>
C-3PO & R2-D2 Diorama Options
#121 Posted : 09 October 2017 09:49:29
Great work MarkBigGrin the base is really coming alongDrool regards PhilCool
#122 Posted : 15 October 2017 19:25:20
Thank you Phil, for you kind comments.
I have done a little more to the duo, I wanted to at least get the lighting wired in the base. First, I had to glue and fix both droids onto the base using some small wooden dowels to hold them in place and make them a little more sturdy.
I then used some 5 minute epoxy glue, and pushing the wiring through the base with the holes I drilled. Then pushing the dowels into the holes on the base.
#123 Posted : 15 October 2017 19:34:12
As you have seen in my previous post, I was going to use a remote circuit board to operate both droids, but having had two of the broads fail on me, I decided to keep it simple as shown. Once I had connected the wiring and tested it, I then screwed together the circuitry casing.
The second picture shows I have attached a plastic base to the underside, using plastic card. I will later cover this in a velvet material.
#124 Posted : 15 October 2017 19:38:00
Here, you can see I have added some more sand, now the droids are in place, around their feet. I used a pipette to carefully drop the sand in place before applying some glue to hold it all together. This will be allowed to dry, before painting as I did before.
#125 Posted : 15 October 2017 21:58:37
Superb work Mark, some excellent modelling tips too....Drool Drool
#126 Posted : 15 October 2017 22:53:40
BigGrin Top work and an excellent how too guide included, just cant get any betterCool
#127 Posted : 16 October 2017 08:21:03
Thank you Alan & Andy for you comments.
#128 Posted : 16 October 2017 11:09:51
All looking great MarkBigGrin really outstanding workCool regards PhilCool
lholland
#129 Posted : 17 October 2017 16:18:37
These look fantastic.
#130 Posted : 17 October 2017 18:50:11
Thank you Phil and Lee for looking in and your kind words.Blushing
#131 Posted : 17 October 2017 19:08:20
Superb work as always!
#132 Posted : 17 October 2017 20:30:19
Great work Mark, looking very impressive.
#133 Posted : 28 October 2017 15:03:12
The diorama is now complete. I have also bought a display case to keep the dust off the duo. Here, you can see I painted the sand around their feet the same as I did last time. I have also fitted some velour to the base to make it look a bit more professional.
Once this was done, I then airbrushed some black around the outer rim to blend in with the base.
I also attached a metal name plate to finish off the model.
Hope you enjoy the pictures, as much as I have enjoyed building these two, and thank you to all who have followed this build and all your contributions over the year.
Here is a link to the full size pictures.
https://www.dropbox.com/...sl8fvTKLmpvIEYHWga?dl=0
Here is the YouTube video show the lights working.
https://youtu.be/ogBObdtSS3w
#134 Posted : 28 October 2017 16:47:09
Fantastic end result and thanks for sharing your “tricks” Cool
Andreas
#135 Posted : 28 October 2017 17:36:28
Groups: registriert
Hi Mark
i love it,Love Love excellent work!!!!
Forum Support Team
#136 Posted : 28 October 2017 17:58:44
They look brilliantBigGrin really enjoyed your build MarkBigGrin outstanding workDrool Drool regards PhilCool
#137 Posted : 28 October 2017 18:14:58
BigGrin Top build Mark and a great resultCool
#138 Posted : 28 October 2017 20:34:40
Thank you all for the kind words and support.Blushing
#139 Posted : 28 October 2017 23:27:09
Simply stunning Mark and a true mark of your skills.....Love Love
gedmac66
#140 Posted : 29 October 2017 18:29:46
Hey Mark ,
Terrific looking duo you’ve got there Love . Thanks for sharing your techniques and tips during this build .
Congratulations , and good luck with the comp . Wink ThumpUp
Ged
8 Pages «<5678>
This page was generated in 0.198 seconds.
