106 Pages «<6566676869>»
#1321 Posted : 12 October 2017 23:13:58
Continuing aft with the marking out.
#1322 Posted : 12 October 2017 23:17:20
Moving further aft on the upper, port hull, marking out the rivet strip guide lines.
I initially envisaged that all this marking out would be a '5 min job'. In reality it took two evenings.Blink I had to redraw some and cross reference measurements with the part-works instructions.
#1323 Posted : 12 October 2017 23:18:20
The attached photo shows the weld lines in place on the lower, port hull.
#1324 Posted : 12 October 2017 23:19:14
Continuing aft showing the weld lines in place.
#1325 Posted : 12 October 2017 23:20:10
This photo shows all the weld lines in place on the lower, port hull.
#1326 Posted : 12 October 2017 23:21:05
Starting to apply the horizontal rivet strips on the upper, port hull.
#1327 Posted : 12 October 2017 23:23:58
The attached photo shows this particular section completed with the horizontal rivet strips on the upper, port hull.
I found it to be more manageable to work in sections like this throughout 'rivet gate'LOL , so that the whole thing didn't seem so daunting.Blink
#1328 Posted : 12 October 2017 23:26:29
This photo shows the horizontal rivet strips laid on the upper, starboard hull, similar to the port side, where I worked on a small section.
#1329 Posted : 12 October 2017 23:27:24
I then continued working on the port side, adding the vertical rivet strips.
#1330 Posted : 12 October 2017 23:28:13
Vertical rivet strips added to the upper, starboard hull.
#1331 Posted : 12 October 2017 23:29:04
I then added vertical rivet strips below the brass strip.
#1332 Posted : 12 October 2017 23:30:01
Then turned the boat around and did the same on the port side.
#1333 Posted : 12 October 2017 23:30:52
Vertical weld lines added to the starboard saddle tank.
#1334 Posted : 12 October 2017 23:31:49
Vertical weld lines added to the front of the port saddle tank.
#1335 Posted : 12 October 2017 23:33:32
Overhead photo showing the front of the port saddle tank weld lines.
#1336 Posted : 12 October 2017 23:37:34
That concludes this week update.
I hope to get a couple of hours modelling in at the weekend plus three evenings next week in which I aim to add the draught marks and COMPLETE THE RIVETING AND WELD LINES!!!!BigGrin Cool
Thanks for looking in and your comments, have a great weekend and happy modelling.BigGrin
#1337 Posted : 13 October 2017 07:13:50
Excellent work PhilBigGrin they really have made a differenceDrool Drool top work BigGrin regards PhilCool
#1338 Posted : 13 October 2017 08:21:56
Looks superb Phil, top notch work....Drool Drool
#1339 Posted : 13 October 2017 09:08:06
Thanks for looking in Phil. It's starting to take shape!Cool
Phil W.BigGrin
#1340 Posted : 13 October 2017 09:09:08
Thank you Alan. Much appreciated!Cool
Phil W.BigGrin
Guest (10)
This page was generated in 0.680 seconds.
