 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,062 Points: 15,332 Location: ipswich
Thanks Tony.
The firewall is 80 sheet styrene covered with ally BMF. I used 80 sheet for the thickness which makes it really rigid and supports the body and front frame really well.
Roy.
roymattblack wrote:Thanks Tony.
Roy. Thanks for that Roy. The bare metal foil does give a really nice finish. Happy Modelling
Beautiful work with all the details Roy
Top Work Roy  lovely to watch your builds  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Many thanks chaps. It's all good fun - even if a bit hair-tearing at times. Again, not much to see other than I've made a start on trimming up and fitting the bonnet section. Only very roughly trimmed at the moment and the arches are nowhere near sorted. Currently fixing a bracing strip inside the top edge of the panel to give it rigidity. roymattblack attached the following image(s):
Very nice Roy. Is it vac formed body work? Happy Modelling
Yes, vac form.
The main shell is fibre glass but I don't use that stuff any more. Far too messy, smelly and nasty to work with. This body is one I've had for years gathering dust in the garage.
roymattblack wrote:Yes, vac form.
Sorry chaps but I just 'tried' to post a LONG message. The forum has been very dodgy today so when I hit 'post' it was all lost...
Thanks for the update Roy. Happy Modelling
More trimming, fiddling and fettling with the bonnet to get a decent fit before I start chopping it about for the louvres, lights and grille. One wheel nearly sorted and a tyre in primer. Just checking for position so it's only standing next to the car. roymattblack attached the following image(s):
Wired wheels look very nice. Happy Modelling
Thanks Tony. I've been rattling on with it today as I'm 'hoping' to get it completed by end October/early November. I've made the rad shell, header tank and side frames for the rad. It's all made from sheet styrene. The weld lines were added using a stained glass window pen. Brilliant for stuff like this as well as rivets. The rad core will be next. The rad isn't fixed in yet as I need to add pipe fixings, relay connections and also build up the fan and shroud which goes on the front of the rad on this car. On we go... Roy. roymattblack attached the following image(s):
A bit more done on the front end. The rad is sorted, fan shroud and fan added. More bits still to fit as well as adding the wiring. Next up will be making and fitting the front wheels. Then it will be on to the back end and sorting the bonnet. It's still quite a bit to go but I'm really aiming at completing mid November. Looking forward to starting a new project... Roy. roymattblack attached the following image(s):
Some nice work Roy  will the new project be another Jag? Al
A bit of a clue here... Still collecting lots of reference. Roy. roymattblack attached the following image(s):
Would that be a GT40 by any chance Al
Hmmmmmm... Wait and see... lol
Another superb build mate. Ken's the name modeling's the game.
Thanks for peeping in chaps. Front wheels now made and fitted - centre spinners need sorting. Next will be the rear end gubbins and wheels... The ol' girl is getting quite heavy now. Roy. roymattblack attached the following image(s):
Still plodding along with this one. The carb air box has been made and fitted but it still needs a few details. Some bracing to add to the rad header tank and then it will be the rear end... Roy. roymattblack attached the following image(s):
Looks fantastic Roy. Really like the sparkly blue paint finish - very smart. Happy Modelling
