Ramp doesn't stop Options
justkelly
#1 Posted : 08 October 2017 20:59:02
Doing issue 57 today. Got everything wired up. When I hit the A button, the ramp descends to the full length of the rams, but then it keeps trying to descend. Only way to stop is to hit A again and it pulls the ramp back up (stops then, thank goodness). The light does work, FWIW.
Anyone know what's going on?
#2 Posted : 08 October 2017 21:16:26
It’s difficult without seeing it, but check the contact pins on both the top and bottom. See whether ther connect when pressing the button.
justkelly
#3 Posted : 08 October 2017 21:54:49
Sorry, what contact pins? Are we talking about the two paddle-looking deals on the top of the motor? Because if so, I noticed that the little "tongue" doesn't ever contact the lower one. It seems to be just short. It does hit the upper one on the journey up, though. I tried poking the lower paddle down on the trip down to see if that triggered a stop, but it didn't seem to. Other than that, not sure what you mean.
#4 Posted : 09 October 2017 11:53:46
It's probable the paddle you mentioned bent, I’m sure when the ramp is moving in the downward/open position, the white plastic cog should bring the top paddle onto the lower paddle, stopping it.
Try that first, and let me know.
justkelly
#5 Posted : 09 October 2017 12:46:13
Yup, that was it. The upper paddle was not attached to the cog. Thanks for your help!
This page was generated in 0.090 seconds.
