Thanks for commenting guys, it's a great kit.
Pack 11 As usual the first two pics start with what came in the box and then a better look at the parts before the stages are covered. The next couple of pics deal with the gearbox assembly before moving onto a rear hub assembly and the start of the rear suspension. Thanks for looking Al Spal attached the following image(s):
Pack 12 Fitting the rear suspension to the gearbox together with some ancillary parts. Al Spal attached the following image(s):
Work very clean, making changes is not always beneficial, it requires a lot of stress
You're making nice progress with this Al and a nice tidy build too, well done.
Kev
Thanks for looking in guys Al
Pack 13 With this pack, the driveshafts are fitted, quarter body panels fitted,the last brake unit assembled and fitted and the final wheel assembled. Oil lines and jacking point are also added in accordance with the instructions. Thanks for looking Al Spal attached the following image(s):
 Looking good Al , its a nice kit to put together Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work Al, looks a excellent kit. Mark Regards Markwarren (Mark) Admin
Thanks for looking in guys  even straight out of the box its a great kit. Al
Thanks for looking in Maurizio Al
Very good build Spal! Collection active: Lotus 97T, Audi Quattro A2, Vw Maggiolino '60
Thanks Francesco, appreciate you looking in.
Pack 14 This pack deals mainly with the heat shield which has to be fitted in several pieces. Have also fitted the oil tank and pipe to the gearbox assembly, the underbody parts and 6 brackets and also the heat exchanger and tailpipe endplates. Thanks for looking. Al Spal attached the following image(s):
Great progress Al
Thanks Dave Al
Looking great Al, another really nice build to add to your collection..... Regards Alan
