106 Pages «<6364656667>»
#1281 Posted : 29 September 2017 10:02:35
Some real dedication and skill being put in on this one.
Looking forward to seeing it all come together under a paint layer - it will look brilliant.
#1282 Posted : 29 September 2017 10:23:54
Thank you Tony!Cool You and me both on the paint front!BigGrin
#1283 Posted : 29 September 2017 10:48:31
Glad you`re at the end of the rivets Confused Blink looks fantastic though well worth your time and effortDrool Drool well done Phil ThumpUp ThumpUp regards PhilCool
#1284 Posted : 29 September 2017 11:01:11
Thanks Phil!Cool Not quite done with the riveting yet, but definitely heading in the right direction!BigGrin
daffy09
#1285 Posted : 29 September 2017 11:56:26
I admire your dedication to this build Phil, and it shows with every rivet.
Very well done
Happy building
David
#1286 Posted : 29 September 2017 12:18:38
Very well done
Happy building
David
Thank you David!Cool I have questioned my dedication at times when I think to myself 'i'm bonkers for doing this'.LOL
Phil W.BigGrin
#1287 Posted : 29 September 2017 13:01:45
Awesome job on the riveting, it will be such an achievement when you do the final strip of rivets Cool I can't imagine too many others will go down this route so well done you.
#1288 Posted : 29 September 2017 13:48:56
Thanks Al!Cool Yep, getting ever closer to finishing this part of the build. Can't wait to get the paint on!BigGrin Been such a long time coming.
The week I finish the rivets, I may crack open a beer or two!
Phil W.BigGrin
#1289 Posted : 05 October 2017 22:32:07
Good evening from 'the Dockyard'.
A fairly quick update tonight as this week I've been concentrating on finishing off my 1/43 scale MG TD build. This particular post will be updated during the next couple of days.
Back to the boat; first off, i realised i had missed some weld lines around the bow area.Blink
The attached photo shows the weld lines that run vertically down from the forward tip of the port saddle tank. The boat is upside down.
#1290 Posted : 05 October 2017 22:32:48
Vertical weld line completed.
#1291 Posted : 05 October 2017 22:34:39
This photo shows the diagonal weld line that connects with the previous vertical one to the part-works supplied brass rivet strip, via a small vertical weld.
#1292 Posted : 05 October 2017 22:35:43
A smaller, vertical weld line, further back on the port side.
#1293 Posted : 05 October 2017 22:38:01
The starboard side was treated the same way. This photo shows the small, vertical weld line, opposite the port one mentioned previously.
#1294 Posted : 05 October 2017 22:39:04
Marking out the weld lines on the lower, port hull at the rear of the saddle tank.
#1295 Posted : 05 October 2017 22:39:39
Erasing a marking out mistake.
#1296 Posted : 05 October 2017 22:40:52
Continuing forward on the lower, port hull, i marked out further vertical and horizontal guide lines.
#1297 Posted : 05 October 2017 22:41:32
Port mid-ships weld line being marked out.
#1298 Posted : 05 October 2017 22:42:42
Starboard mid-ships weld line marked out.
#1299 Posted : 05 October 2017 22:47:19
#1300 Posted : 05 October 2017 22:51:00
Well, that concludes this weeks update. As i mentioned before, i didn't get that much done this week, but i hope to make up for lost time this weekend.
For next week's update, i aim to get all the weld lines applied to the marking out in this post and also apply weld lines to the end of both saddle tanks. By doing it this way i can still handle the boat, as i continually turn it round to work on both sides.
This will then leave the mid-ships rivets, the remainder of the saddle tank weld lines and the port, mid-ships draught marks to be completed the week after.
Thanks for looking in and your comments, have a great weekend and happy modelling.
Phil W.BigGrin
Guest (12)
This page was generated in 0.484 seconds.
