3 Pages 123>
Two Jags Options
#1 Posted : 25 September 2017 23:49:09
Hi All, BigGrin
As a Jag owner I couldn`t let this go by.
Just wish I could afford a real E-type. Crying Crying
I`ve got up to issue 24 delivered and thought I`d make a start.
The first thing that really impressed me was the "Growler" badges on the front bar and steering wheel. Cool Cool
So here we go, just a small starter for you:
Pic 1: The front bar with Growler badge.
Pic 2: Oil filler cap on the rocker cover.
Pic 3: Rocker shafts installed in cylinder head.
Pic 4: Rocker covers in place.
Pic 5: Growler badge in centre of steering wheel.
Finally the start of the first wheel.
Fumbled a bit with the first layer of spokes, but soon realised that if you fit spokes seperated by a gap it held the wheel straight. This will help when fitting the rest of the second layer of spokes. Just my method that works for me. Arrows show where I`ve started the second layer of spokes. Pic 6
That`s all for now, more soon. BigGrin
Happy building.
#2 Posted : 26 September 2017 07:51:51
Good to see another E-Type underway, great start Cool
Two Jag's reminded me of the former deputy PM John Prescott, often nicknamed "two Jag's" because of owning 2 Jag's, though recently downsized to 1 to help save the planet Laugh
#3 Posted : 26 September 2017 09:41:41
Nice one Derek, a great start and I'm sure you'll love putting her together..... Count me in as one of your followers.....Cool Cool
#4 Posted : 26 September 2017 12:27:51
Nice start DerekBigGrin look forward to your next updateDrool regards PhilCool
#5 Posted : 26 September 2017 19:29:20
Nice start Derek Cool
#6 Posted : 26 September 2017 21:07:37
Glad to see you open your account on the Jag Derek BigGrin looks good.
#7 Posted : 29 September 2017 00:20:02
Thanks for all the interest. Cool
Also good to see the "Two Jags" title wasn`t missed. LOL Though not sure it was all down to saving the planet, more the embarressment that "WE" the public were paying for them both. Blink
Anyway on with this update.
I`m working on the wheel a little at a time, so will update on that at a later time.
Issue 6-8 deal with building the drivers door:
Pic 1 shows the outer door handle fitted.
Pic 2 The window is fitted.
Pic 3 The door hinge.
Pic 4 The inner door surround.
Pic 5 The inner panel has three handles fitted.
Pic 6 Inner door panel and two trim strips are fitted.
No problems/issues with this, all came together very easily.Love
In issue 9 the seat back and base are fitted to the seat frame. Pic 7
May need to play around with the seat base a bit at a later date to get it to lay a bit flatter, we`ll see.
That`s all for this update, see you soon.
#8 Posted : 29 September 2017 08:07:35
Nice update Derek, looks like you're making steady progress...Cool Cool
#9 Posted : 29 September 2017 08:32:14
Nice going Derek, looking good.
#10 Posted : 01 October 2017 21:47:39
Thanks for all the views and opinions.
Cool Cool Cool Cool
Time for the next update.Blink
Issue 10: starts with the assembly of the upper manifold and throttle linkage. Pic 1
Issue 11: adds the lower manifold and carb suction chambers. Pic 2
Now, issue 11 carries on with: Petrol feed pipe, air balance pipe and air cleaner.Blushing Blushing In my enthusiasm forgot to get a pic.
In my poor defence.LOL Flapper LOL
Issue 12: fits the starter, distributor and the afore mention manifold to the right hand engine block. Pics 3+4 (side-on and above)
Next update soon.
#11 Posted : 01 October 2017 22:37:14
Progressing nicely Derek, looks good....Cool Cool
#12 Posted : 01 October 2017 23:24:52
Its coming along Derek BigGrin its easy to forget to take pics when your engrossed in the buildLOL
#13 Posted : 02 October 2017 10:07:05
Nice work Derek, the engine detail does look rather nice Cool
#14 Posted : 02 October 2017 17:50:58
Hi All, BigGrin
Gradually working my way into this build and now up to issue 13. Blink
Thanks to Alan, Al and Dave for your kind comments.Cool
So, this update will cover issues 13 + 14.
Issue 13:
Fit the filter head to the right hand engine block. Pic 1
Fit the model`s battery box to the left hand engine block. Pic 2
Issue 14:
Construct and fit the ignition coil to the cylinder head. Pic 3
Construct the front plate, with pulleys and dynamo. Pic 4
Issue 15 is complete and update coming soon, but for now pics below.
#15 Posted : 02 October 2017 23:14:57
As promised here`s issue 15, BigGrin
The manifolds are fitted to the left-hand engine block.Pic 1
The rev counter connector is fitted to the end of the cam cover, (watch out for the carpet gremlins with this piece, it`s tiny). Pic 2
Fit the cylinder head to the left-hand engine block.Pic 3
Attach the front pulley plate and then combine both sides of the engine block. Pic 4
Now we add some real detail by connecting the coil lead and ignition leads to the distributor. Pic 5
Then the plug leads to the cylinder head. Pic 6
It`s now looking like an engine. Cool Cool Cool
Issues 16 - 18 build the left door which is a copy of the right, so I`ll post a pic when I pick up again at issue 19.
Until then here`s the pic`s for this update.
#16 Posted : 05 October 2017 00:28:44
Hi All, BigGrin
So here`s the next update.
As stated before the left door is just a duplicate of the right, so just one pic. Pic 1
From here the build moves to the front frame that will house the engine and have the front suspension mounted to it.
Issue 19 supplies the right hand inner frame.
Issue 20 supplies the upper and lower wishbones for the suspension on the same side and the result is shown in Pic 2.
Issue 21 supplies the left hand inner frame.
Issue 22 supplies the upper and lower wishbones for the suspension on the same side. Both sides of the frame are shown in Pic 3.
Issue 23 adds the supplied front crossmember and is shown in Pic 4.
Issue 24 adds two brace bars to the right hand side of the frame shown in Pic 5.
To come in the next update:
More additions to the front frame.
Then adding the the front disc`s and brakes along with the shock absorbers.
Happy Building
#17 Posted : 05 October 2017 06:52:49
Nice update DerekBigGrin will you be weathering this oneConfused regards PhilCool
#18 Posted : 05 October 2017 11:50:40
Hi Phil, BigGrin
Thanks for looking in. Cool
I`ll not be weathering as such, but I`m thinking of back tracking on the engine to paint in some more detail.
#19 Posted : 07 October 2017 20:49:07
Hi All, BigGrin
This is the last update for now, as waiting for next part.Blink Blink
So:
Issue 25 fits the left hand upper and diagonal brace. This is a duplication of the right hand side. Pic 1
Issue 26 you fit the steering rack bracket to the front of the main frame (arrowed)in Pic 2
and the left hand lower brace (arrowed):note the "L" on the brace. Pic 3
Issue 27 you make up the the brake disc, brake caliper and and right hand hub. Pic 4
This assembly is then added to the upper and lower wishbones. Pic 5
The final part for this issue is to fit the shock absorber. Pic 6
Issue 28 is a duplication of issue 27 fitting the same parts to the opposite side of the main frame. Overall view in Pic 7.
So that`s it all up to date.Cool
Other things to do to fill in the time, but will also have some time to do more to the wheel.
Happy building
#20 Posted : 08 October 2017 09:46:41
Steady progress Derek and looking good....Cool Cool
3 Pages 123>
This page was generated in 0.267 seconds.
