The final two pictures are C-3PO and R2-D2 placed on the display as a test fit. As you can see, I still have the centre foot on R2 to finish off. Then it’s onto the diorama, nearly there.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Stunning work Mark, love it.... Regards Alan
these would be spectacular at large scale.Considering the small size of these models this work it outstanding
Many thanks Alan, Carl. Painting the legs on R2, almost took as long as the big one I’m building. Mark Regards Markwarren (Mark) Admin
They look outstanding mark  top work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Many thanks Phil Mark Regards Markwarren (Mark) Admin
 Rank: Semi-Pro Level 2 Groups: Registered
Joined: 08/05/2016 Posts: 79 Points: 251 Location: Perth, W.Australia
G'day Mark , WOW!!! . Gorgeous looking Droids  . Your attention to detail and weathering is breathtaking ( as usual ! ) , not to mention what you're able to cram into those cramped spaces for lighting them up  . Can't wait to see them in their eventual dio Cheers Ged
Joined: 06/08/2015 Posts: 276 Points: 817 Location: Monrovia, Ca
Looks really nice, Mark. Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
Many thanks for looking in guys, and your kind words and support. Mark Regards Markwarren (Mark) Admin
Beautiful work Mark, looks fantastic.
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
superb looking. Love the lights too.
Thank you Graeme and Lee, I've really enjoyed building this. Regards Mark Regards Markwarren (Mark) Admin
I have started working on the base scene, where both droids with be placed. First, I lightly sanded the glossy base for the putty to adhere too. I then took a few small stones from the garden and placed them where I wanted them to be in the scene, as shown in the second picture. I then mixed some Durham’s water putty and spread it over the base with a spatula and added the stones, pushing them gently into the putty. I then left it for 24 hours to dry off. You can also see I pushed through from the bottom a wire where I had drilled the holes that are for the lighting cables.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Once the putty had hardened, I then sprayed some ochre brown with my airbrush. Once this had dried, I then applied some crackle paint in areas to give it a more rugged look. I then placed both the droids onto the stand and drew around their feet. I then drilled holes to the underside of both droids, and into the base. This will be where I will place a small dowel to help support both C-3PO and R2 when gluing them on.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Here, you can see I placed a small amount of fine sand in areas around the stones/rocks. I then used some sand cement that has the consistency of skimmed milk. Using a pipette, I carefully placed it over the sand and left it over night to dry hard. As you can see in the second picture, I added some more smaller stones and more sand.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
The final pictures show how it starts to look one sprayed with ochre brown and then dry brushed with a lighter sandstone colour. There is still much more to do with the base as once I place both the droids, I will add more sand around their feet and some more fine air brushing is also needed for the final effect.Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Beautifully done Mark..... Regards Alan
Hi Mark. Great work on the bases they are looking fantastic. Ian Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thank you Alan & Ian for you kind comments. Regards Mark Regards Markwarren (Mark) Admin
