8 Pages «<45678>
C-3PO & R2-D2 Diorama Options
#101 Posted : 24 September 2017 20:54:44
The final two pictures are C-3PO and R2-D2 placed on the display as a test fit. As you can see, I still have the centre foot on R2 to finish off.
Then it’s onto the diorama, nearly there.
#102 Posted : 24 September 2017 22:42:13
Stunning work Mark, love it....Love Love
#103 Posted : 24 September 2017 22:49:23
these would be spectacular at large scale.Considering the small size of these models this work it outstanding
#104 Posted : 25 September 2017 07:27:32
Many thanks Alan, Carl. Painting the legs on R2, almost took as long as the big one I’m building.
#105 Posted : 25 September 2017 10:23:00
They look outstanding markDrool top workBigGrin regards PhilCool
#106 Posted : 25 September 2017 15:27:39
Many thanks Phil
gedmac66
#107 Posted : 25 September 2017 17:23:25
G'day Mark ,
WOW!!! . Gorgeous looking Droids Love . Your attention to detail and weathering is breathtaking ( as usual ! ) , not to mention what you're able to cram into those cramped spaces for lighting them up Confused .
Can't wait to see them in their eventual dio Drool
Cheers Ged
#108 Posted : 25 September 2017 19:15:51
BigGrin Top work from the weathering master as always looking forward to seeing the finished resultCool Drool Drool Love
scraperjawa
#109 Posted : 25 September 2017 19:26:35
Looks really nice, Mark.
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Finished Builds: Millennium Falcon
#110 Posted : 25 September 2017 20:37:49
Many thanks for looking in guys, and your kind words and support.
#111 Posted : 25 September 2017 21:05:53
Beautiful work Mark, looks fantastic.
lholland
#112 Posted : 26 September 2017 12:53:17
superb looking. Love the lights too.
#113 Posted : 26 September 2017 13:38:05
Thank you Graeme and Lee, I've really enjoyed building this.BigGrin
#114 Posted : 08 October 2017 18:45:42
I have started working on the base scene, where both droids with be placed. First, I lightly sanded the glossy base for the putty to adhere too. I then took a few small stones from the garden and placed them where I wanted them to be in the scene, as shown in the second picture.
I then mixed some Durham’s water putty and spread it over the base with a spatula and added the stones, pushing them gently into the putty. I then left it for 24 hours to dry off. You can also see I pushed through from the bottom a wire where I had drilled the holes that are for the lighting cables.
#115 Posted : 08 October 2017 18:47:05
Once the putty had hardened, I then sprayed some ochre brown with my airbrush. Once this had dried, I then applied some crackle paint in areas to give it a more rugged look. I then placed both the droids onto the stand and drew around their feet. I then drilled holes to the underside of both droids, and into the base. This will be where I will place a small dowel to help support both C-3PO and R2 when gluing them on.
#116 Posted : 08 October 2017 18:47:56
Here, you can see I placed a small amount of fine sand in areas around the stones/rocks. I then used some sand cement that has the consistency of skimmed milk. Using a pipette, I carefully placed it over the sand and left it over night to dry hard. As you can see in the second picture, I added some more smaller stones and more sand.
#117 Posted : 08 October 2017 18:48:55
The final pictures show how it starts to look one sprayed with ochre brown and then dry brushed with a lighter sandstone colour.
There is still much more to do with the base as once I place both the droids, I will add more sand around their feet and some more fine air brushing is also needed for the final effect.
#118 Posted : 08 October 2017 20:34:21
Beautifully done Mark.....Drool Drool
#119 Posted : 08 October 2017 23:01:37
Hi Mark.
Great work on the bases they are looking fantastic.
Ian Cool BigGrin
#120 Posted : 09 October 2017 07:39:34
Thank you Alan & Ian for you kind comments.
8 Pages «<45678>
This page was generated in 1.119 seconds.
