106 Pages «<6162636465>»
#1241 Posted : 21 September 2017 23:12:01
Starboard side draught marks completed.
#1242 Posted : 21 September 2017 23:13:22
Time to start the next sections of riveting!Blink
I continued down the port side below the brass strip as can be seen from the attached photo.
#1243 Posted : 21 September 2017 23:13:50
Continuing aft.
#1244 Posted : 21 September 2017 23:14:36
I then worked on the same section, starboard side.
#1245 Posted : 21 September 2017 23:15:19
Continuing aft on the starboard side.
#1246 Posted : 21 September 2017 23:16:10
Back to the port side to continue with the rivets.
#1247 Posted : 21 September 2017 23:18:01
I worked in this way all the way aft on both sides.
It was then a question of marking out in pencil the next sections for riveting.
The attached photo shows the tip of the stern with completed rivets and also the next section marked out.
#1248 Posted : 21 September 2017 23:18:51
The attached photo shows the continuation of marking out the remainder of the riveted sections.
#1249 Posted : 21 September 2017 23:20:28
This photo shows further pencil markings for the rivets. Marking out these sections took longer than expected due to the curve of the hull.
#1250 Posted : 21 September 2017 23:21:18
More marking out.
#1251 Posted : 21 September 2017 23:22:23
This photo shows the port side of the rudder mount, complete with rivet detail.
#1252 Posted : 21 September 2017 23:23:27
Completed rivet detail on the starboard side of the rudder mount.
#1253 Posted : 21 September 2017 23:24:30
A different angle showing the rivet detail on the rudder mount.
#1254 Posted : 21 September 2017 23:28:21
Well that concludes this week update.
The stern should be completed next week before i move onto the saddle tank weld lines and riveting along the length of the casing.
There is light at the end of the tunnel. Just!Blink
Thanks for looking in and your encouraging comments!Cool
Have a great weekend and happy modelling.BigGrin
#1255 Posted : 21 September 2017 23:40:07
Nice update Phil, great work, it's been a long tunnel.LOL
daffy09
#1256 Posted : 22 September 2017 00:38:48
Good work Phil, those rivets are making a world of difference to the appearance of her. That section at the stern looked a little tricky but you've pulled it off with flying colours. Looking forward to your next update
Happy building
David
#1257 Posted : 22 September 2017 09:22:12
Happy building
David
Thanks David!Cool Yep, was a little tricky, especially marking out around the tapered shape of the hull on the underside. I would mark out with what I believed at the time to be the correct intervals, only to look at it from distance and realise some were not aligned. Thankfully, marking out in pencil meant I could erase any mistakes and redraw. Granted, the pencil lines are a little dark in places, but once the undercoat goes on, only the rivets will show.
Phil W.BigGrin
#1258 Posted : 22 September 2017 10:05:51
Beautiful work once again Phil, well done....Cool Cool
#1259 Posted : 22 September 2017 10:59:08
At last you`ll be able to get a good nights sleepLOL great work as all ways PhilBigGrin regards PhilCool
#1260 Posted : 22 September 2017 11:13:17
Hi Phil.
Cool Looking fantastic. The rivets really finish off the look of the hull. BigGrin Drool Ian
This page was generated in 0.436 seconds.
