calibrating z axis pack 11 guide pg. 288 #3 Options
sterling1977
#1 Posted : 20 September 2017 17:20:59
Rank: Newbie
I am not sure if I did something wrong when fully finishing the z axis or (table). However when I am trying to calibrate it using the pack 11 guide. It only moves down halfway when I press the home button on the icon. This problem has arisen when calibrating using pack 11 guide, pg 288 #3. Can you give me some advice as to what I can do to fix this problem and continue the calibration process? Thanks
#2 Posted : 20 September 2017 18:00:27
Hi sterling1977,
I am forum support for USA.Can you take a picture of where the table ends up after you press the home button.Can you manually move the table lower if you use the controls in Repetier host.Have you checked the connection for the z axis limit switch?
CaRL
sterling1977
#3 Posted : 26 September 2017 18:53:06
Rank: Newbie
I am not sure how to manually calibrate the table using the program. So I am still unsure as to how to proceed in the calibration process. I tried using repetier to manually move it down, but it just buzzes when I attempted to move the table manually and of course the table does not move?
#4 Posted : 26 September 2017 19:38:04
Please reply to my PM regarding this issue
USA forum support
This page was generated in 0.283 seconds.
