11 Pages «<7891011>
Daffy's L'HERMIONE La Fayette Options
#161 Posted : 20 September 2017 01:27:38
Looking good, don`t think you`ll need much filler on that. WTG
Cool Cool Cool Cool Cool
#162 Posted : 20 September 2017 06:52:19
You are really progressing with this DavidBigGrin looks superbDrool regards PhilCool
daffy09
#163 Posted : 20 September 2017 11:37:09
Thanks Derek, I hope not, but I didn't lay the planks too tightly in some places and so there are a few large gaps. For some reason, it looks better in the images than it does on the bench. The instructions want us to put a thin layer of filler all over and then sand down again, but I think that would make unnecessary work.
Happy building
David
daffy09
#164 Posted : 20 September 2017 11:40:56
Thanks Phil, glad you like it. Still a ton of work to do before I can start painting the hull, but I'm enjoying the process.
Happy building
David
#165 Posted : 22 September 2017 13:13:04
Hi David.
Cool Looking fantasticBigGrin
Ian
daffy09
#166 Posted : 22 September 2017 17:44:55
ian smith wrote:
Hi David.
Ian
Thanks for the compliment Ian. Not long now before she gets her paint job. Then we can really get going.
Happy building
David
daffy09
#167 Posted : 24 September 2017 18:18:01
Quick update on the HERMIONE build:
STAGE 13
Hello again,
This weekend I've started on the filling of the hull.
I'm using a new product to me called 'red devil OneTime lightweight filler' (see link below). Have to see how I get on with it.
filler
I've gone over the hull for the first time with it and will sand it down again tomorrow. It will then be ready for its first coat of primer which will show up any more imperfections which need either filling up or sanding. More on this to follow.
Thanks for all your very welcome comments and for looking in again.
Happy building
David
#168 Posted : 24 September 2017 19:04:56
Looking good David. I'll be interested to see how the filler works out.
#169 Posted : 24 September 2017 19:23:52
BigGrin A bit more sanding to do but the results should be goodCool
#170 Posted : 24 September 2017 19:58:06
BigGrin Looking good David I will be very interested in how the filler turns out as I use cheep and cheerful interior filer from BQ Cool
Martyn
#171 Posted : 24 September 2017 22:33:50
Very nice progress David, look forward to seeing how she looks after the first coat of primer has been added.....Cool Cool
#172 Posted : 25 September 2017 10:26:27
Nice progress so far David. The planking will look excellent once filled and sanded.Cool
daffy09
#173 Posted : 25 September 2017 16:15:46
@Pemberg
@arpuchase
@martynIngram
@Gandale
@stickyWickett
Thanks for looking in guys, your comments are welcome.
@Martyn and Graeme. I was using the 'cheap & cheerful' alternatives but thought I'd give a 'specialist' filler a try. It is indeed much lighter than I was used to and it is much finer and filled the smaller gaps much easier but time will tell once it's been sanded and primed.
I'm looking forward to getting the primer on but I have yet to get out and buy any.
My partner seems to be using her car more and more these days and getting to my local model shop is proving difficult for me (the closest is a half-hour drive from me). I know what you're going to say, - why not buy it online? - but I want to purchase some yellow paint as well, and I can't get a perfect match from the online catalogues, so the model shop seems a good option for me being able to compare different shades with it in my hands so to speak.
I'll let you all know how I get on.
Thanks again for looking in.
Happy building
David
#174 Posted : 25 September 2017 18:30:36
BigGrin Well done for supporting the bricks and mortar shops David I love going to the one In Bury St Edmunds the wife doesn't as I spend to much in there lol LOL
clockmaker
#175 Posted : 27 September 2017 17:30:24
Hi David.
I think I am slightly in advance of you with the hull build and and have just come against a problem which I don't think is of my making. I am about to start on stage 17 which requires the use of a scraper shown in image 120.
I had ordered a scraper set but on investigation the correct shape was not present on the scrapers I had been sent. After long discussions with one of the customer help staff we realised that there are two scraper sets available, 17000 and 17001.
Nowhere could I see an option on the purchasing web site to select between these different versions and I had been sent the wrong one for this particular stage. It would appear from the notes relating to this stage that it may be necessary to have both sets.
Does anyone know if both scraper sets are necessary for Hermoine ?
Hope the sanding down and painting goes well.
Norman
clockmaker attached the following image(s):
#176 Posted : 27 September 2017 20:53:45
@ Clockmaker, the issue you have raised regarding the shapers is being looked into....
daffy09
#177 Posted : 27 September 2017 22:33:30
clockmaker wrote:
Hi David.
Norman
Hi Clockmaker, I see Gandale is looking into this for you but for my part, I cannot say for certain if both sets are required for the 'Hermione' as I haven't yet reached the stage of using them. However, I played it safe and ordered both sets direct from the Artesania Latina website shop.
Can I say how much I admire your paint job, it looks great.
PS: Maybe you could tell me what colour yellow you used on the hull, as it really works well, and I can't seem to find a shade that matches the colour on the full-size poster included in the kit?
I look forward to seeing more of your build on here as I'm sure others would as well.
Happy building
David
clockmaker
#178 Posted : 28 September 2017 11:32:57
Hi David.
Thanks for comments on painting. Normally I make a mess of painting. Was very pleased how it came.
I used the Admiralty range of water based paints obtained from Cornwall Model Boats. The yellow is their yellow ochre.
I brush painted the white and yellow but air-brushed the black and blue as I though there would be less chance of bleeding under the masking tape.
Thanks for the Artesania Latina web site info. Found what I wanted. Much more comprehensive site.
Norman.
daffy09
#179 Posted : 28 September 2017 12:05:44
clockmaker wrote:
Hi David.
Norman.
Your'e welcome Norman. Thanks for the 'heads up' on the paint. I thought yellow ochre would be too dark but looking at your picture it seems fine. I'm hoping to get out this afternoon to buy my primer so I can get on with finishing the hull.
Happy building
David
#180 Posted : 28 September 2017 14:53:16
Having looked into this I can confirm if you wish to create the mouldings on the various strips of wood on this build then you will need both sets of Artesania Microshapers, as recommended as an optional extra in Stage 17 of the build instructions.  (Artesania Ref 27300 and 27301. The tools web page is presently being looked at and members will be updated as soon as information is forthcoming.
The shapers however can also be sourced from here...
http://www3.towerhobbies.../wti0001p?&I=LXGEGH
http://www3.towerhobbies.../wti0001p?&I=LNGEGJ
Guest (5)
11 Pages «<7891011>
This page was generated in 0.272 seconds.
