4 Pages <1234>
Baz's DC-3 Options
#41 Posted : 17 September 2017 23:00:24
Think you're doing a great job with this Baz, the framing looks spot on....Drool Drool .. Very well done, look forward to seeing your next update....
#42 Posted : 18 September 2017 20:45:03
Interesting to know that the plastic mouldings are part of the kit Baz, thanks for that and I agree, it'll be a real shame to cover up the frames .... but think how nice she'll look with all of those polished aluminium panels fitted?! Drool Cool ThumpUp
#43 Posted : 18 September 2017 20:57:27
Looking good, you're doing a great job.
Bazholding
#44 Posted : 19 September 2017 17:49:43
Thanks for the comments
the tail section is has a lot of pieces compared to the rest of the frame.
I filed a lot of material from the metal parts but still not happy with the fit so will need to add filler and shape them.
Bazholding attached the following image(s):
Current builds: HMS Victory, hachette black pearl, DC-3, R2-D2, Millennium Falcon
#45 Posted : 19 September 2017 19:20:03
Hi Baz,BigGrin
Looking good. Cool
Couple of things to remember.
Make sure that all the stringers when fitted are flush with the wooden frames (gives a better surface to fix the plating to) and when fitting the metal shaped pieces, use a scrap of plating material as a guide to make sure that the metal parts are set at the correct level. I acheived this by laying the scrap of plating material on the frames next to where the metal parts are to be fitted, then fix the metal parts level to the plating.
Hope this helps, keep up the good work.Drool
Bazholding
#46 Posted : 22 September 2017 17:54:36
for the nose section I tried to make the stringers as flat as possible then give the entire piece a light sanding over the stringers.
good tip using a scrap of the covering though, thanks.
I wasn't happy with the fitting of the metal parts and I was tempted to remove them and try again but after fitting the rest of the wood parts I dont think I can get a better fit.
#47 Posted : 22 September 2017 18:38:41
Hi Baz,BigGrin
That looks pretty good. Cool
You have a little bit of scope with the plating to make some minorr adjustments for fit to the metal parts, so should be Ok.
The metal parts are quite soft, so if "essential" you can file (very carefully)a bit of material away. Do be very gentle in this approach or you may alter the shape noticeably.
I would wait until you have all the stringers fitted and then recheck the fit of the plating, using the piece of scrap as before.
Keep up the good work.BigGrin
#48 Posted : 22 September 2017 20:26:29
Nice work Baz, very neat and tidy - well done. Cool ThumpUp
#49 Posted : 22 September 2017 22:36:32
A build that requires patience and you have plenty of that Baz, all looking great.....Cool Cool
Bazholding
#50 Posted : 22 September 2017 23:54:44
Thanks everybody
I have now painted a base coat on the last of the wooden parts for the wings, once I have put those together I’ll start fitting the stringers onto all the sections and complete any sanding/shaping works that are needed
#51 Posted : 23 September 2017 10:12:32
Really coming along BazBigGrin great work Drool regards PhilCool
#52 Posted : 23 September 2017 18:23:57
Really nice work Baz, keep the updates coming Cool
Bazholding
#53 Posted : 27 September 2017 19:43:09
had a few problems with the wings, first a few pieces delaminated then i started to put the left wing together backwards. oops
woodwork for the left wing is now all complete.
i used 4 magnets to hold crew/radio room in place. it holds well but not strong enough so I have drilled an another 4 holes. think i will use the top 2 for locator pins and the bottom 2 for magnets.
#54 Posted : 27 September 2017 19:51:05
That all looks very nice and you have put it all together so neatly.
#55 Posted : 27 September 2017 20:45:43
Very nice work, it's really starting to come together.
#56 Posted : 28 September 2017 06:37:40
Great update BazBigGrin looks very impresive even with one wing onCool Drool looking forward to your next updateDrool Drool regards PhilCool
#57 Posted : 28 September 2017 07:07:50
Well done Baz, looks good.
Cool Cool Cool Cool
#58 Posted : 28 September 2017 07:11:52
Looks excellent, nice work.Love
#59 Posted : 28 September 2017 12:13:39
Lovely work again Baz and very nice to see one of these progressing beyond the early stages. It looks very cool to see a full fuselage with wings attached and no skin applied, you're making a great job of this!
I particularly like those frontal photos, well done. Cool ThumpUp
#60 Posted : 28 September 2017 15:47:50
Looking impressive Baz Cool your doing a great job.
4 Pages <1234>
This page was generated in 0.221 seconds.
