 Rank: Pro  Groups: Registered
monzaandre attached the following image(s):
probaly last update for this weekend as I am heading to the RACES !!! Singapore GP is in town.... lets rolllllllll
Some very nice detailing, looks excellent. Mark Regards Markwarren (Mark) Admin
Nice to see it all coming together  well done. Al
Just stunning
Next up engine mounting plates. as I really dont like Phillips screws I decided to drill out the imposed nuts/bolts and create standoff bolts with nuts as per the original. I have also covered up the additional hole that is intended to mount the phillips screw and fixed the part with the 2 standoff bolts. TIP: I have bought cheap watch maker screw kits on ebay, they sell for 2 or 3 bucks for 300 pieces. not all are usable but a good few are.... monzaandre attached the following image(s):
Now I can start fitting the turbos and exhaust headers that I painted and prepared earlier on monzaandre attached the following image(s):
Turbo Waste Gate installed. Pipes will come later once underbody is installed. I still need to airbrush the pipe tips and the underbody outlets monzaandre attached the following image(s):
Finally the gearbox and the engine are married to the underfloor monzaandre attached the following image(s):
the carbon cover of the underfloor turned out pretty OK monzaandre attached the following image(s):
Guest (5)
