Micro-mesh Craft Kit Options
#1 Posted : 16 September 2017 22:13:18
BigGrin Hi All
Just received this kit that contains pads, sticks, fluid and cotton flannel/buffing cloth.
Nine colour coded pads are included bronze being the coarse one at 1500 then 1800, 2400, 3200, 3600, 4000, 6000, 8000 and the last being gray at 12000 fine.
Three sanding sticks with a different grade on each side 100MX/150MX,180MX/240MX and 400MX/600MX.
A bottle of liquid abrasive and a cotton buffing cloth.
Instructions are included from the manufacturer and the supplier to get the best from your kit
All in all a comprehensive polishing kit that will give perfect results every time. There are several versions of the kit designed to polish various items go to the link below to see whats available:-
https://www.ebay.co.uk/s...-mesh+kits&_sacat=0
#2 Posted : 17 September 2017 00:03:55
Had this set for about 6 years. Still going strong, haven't lost their grit. I used them on canopies and flatting down for decals.
Chris Cool
#3 Posted : 17 September 2017 00:11:39
I can also approve this mini polishing kit.Cool
The liquid polish and cloth will remove "minor" blemishes from plastic canopies and return them to a clear finish. (From my experience)
#4 Posted : 17 September 2017 08:15:14
#5 Posted : 17 September 2017 09:16:46
They are very good sets indeed. I had the set some years ago but rather than the pads mine had strips of polishing material with a foam pad you wrapped them around.
Lasted for ages.
#6 Posted : 17 September 2017 09:25:39
I have recently bought this as well, also bought the micro mesh buds, look like cotton buds, for the hard to get at areas. They come in exactly the same coarse grades as the pads.
#7 Posted : 17 September 2017 10:31:16
I have been using 'Micro-mesh' for years and wouldn't be without it. Great for polishing aircraft canopies, the 12000 grit followed by a coat of 'Johnsons Klear' will leave you with a much clearer view into the cockpit than a standard kit canopy ever would even with it fully closed!
Great stuff for polishing out scratches and mould lines!! Cool ThumpUp
#8 Posted : 17 September 2017 11:19:16
Never used them before will have to get a set at the end of the month BigGrin thanks Andy Cool regards PhilCool
#9 Posted : 17 September 2017 15:14:55
Also have this pack and definitely recommend its use.
#10 Posted : 17 September 2017 18:01:52
Had mine for about 3 years and its had a hammering LOL its a great kit I haven't used the liquid polish very much though
This page was generated in 0.163 seconds.
