51 Pages «<2021222324>»
DaDokta`s Build Options
#421 Posted : 28 July 2017 21:17:14
Very neat, looks fab.....Drool Drool
NikonD60
#422 Posted : 29 July 2017 20:01:45
Looking great Walter. Keep up the good work.
Alan.
Today is the tomorrow you wished for yesterday!
#423 Posted : 29 July 2017 20:30:39
Stunning work as always Walter Cool
#424 Posted : 06 August 2017 15:43:48
Hi Walter,
Your attention to detail is admirable. Excellent.
#425 Posted : 06 August 2017 18:24:37
This is coming along quite nicely Cool
Will look stunning once its all finished Cool
#426 Posted : 07 August 2017 00:20:44
Nice work Walter she's looking grand. Well done mate.
Chris Cool
#427 Posted : 08 August 2017 08:19:11
Thanks for your nice comments, guys!
I`ve been on a vacation last week so i couldn`t post an update.
So here`s my recent progress.
I completed the gratings of the beakhead - wanted to achieve a flat platform.
As there was some angle between the beakhead-frames i corrected that for the beakhead main rail to be able to run in the right straight angle.
Built the forward stools.
#428 Posted : 08 August 2017 12:52:03
Looks good Walter Cool
NikonD60
#429 Posted : 09 August 2017 09:38:03
Looking good Walter. Neat job.
Alan.
#430 Posted : 14 August 2017 07:18:07
Thanks Al and Alan!
The beakhead main rail was next.
As the main rail directly ends in the main timberhead i attached the curved part of the rail to a 4x4mm wood piece.
I also modified the foremost beakhead-frame - as there is no horizontal part on the real Vic.
#431 Posted : 14 August 2017 07:38:43
Drool Lovely work Walter your attention to detail is stunning Cool
#432 Posted : 14 August 2017 11:07:57
Nice work Walter, she's looking good.
#433 Posted : 17 August 2017 13:13:59
Hi Walter,
Great update as always.
#434 Posted : 17 August 2017 13:59:01
Nicely done Walter BigGrin
#435 Posted : 22 August 2017 15:24:41
Cool Looking very good walter.BigGrin
#436 Posted : 15 September 2017 07:22:58
Hi there!
It´s been a while - i was on a two weeks vacation.
My next project was the completion of the bow rails.
What i wanted to achieve was the look as on the real ship, where the rails run "through" the beakhead frames.
#437 Posted : 15 September 2017 07:26:26
1.first step was to remove the lateral parts of the beakhead Frames - with that removing the preformed Slots - and being able to Position the rails in the right place. This i had done previously.
2. I attached the rails to the frames in the correct position.
#438 Posted : 15 September 2017 07:31:00
3. I prepared some 3x1mm wood strips. I tried to do the painting before attaching them - but somehow failed with the masking and it looked ugly.
4. I attached the strips over the rails - connecting the stem with the main rail.
5. The gaps between the strips and the frames were filled with wood filler, sanded and painted.
#439 Posted : 15 September 2017 07:35:17
Finally i had to redo the blue fields.
This time - after masking - i applied a layer of yellow to seal the tape ( which was the step i forgot the first attempt - causing the blue paint to run under the tape).
Then applied the blue colour.
This time i was satisfied with the result ( still have to do the starboard side).
I think i could achieve the look i had in mind with the rails running through the frames.
#440 Posted : 15 September 2017 07:47:25
That looks really neat. A lot of skill putting this part of the ship together i can see but your end result is well worth the time you put in.
Guest (10)
