106 Pages «<6061626364>»
#1221 Posted : 14 September 2017 22:05:48
Working aft, marking out the guide lines.
#1222 Posted : 14 September 2017 22:06:52
Continuing aft.
#1223 Posted : 14 September 2017 22:07:52
Completion of marking out for this section on the starboard side stern.
#1224 Posted : 14 September 2017 22:12:42
That concludes this week's update. As I said before, a slow start this week, but that's the way it goes sometimes. Sleep
Next week i'll be back on four cylinders and hope to have the majority of the rivets laid onto the stern. Then the weld lines and draught marks follow the week after.BigGrin
Thanks for looking in, have a great weekend and happy modelling!BigGrin
#1225 Posted : 14 September 2017 22:13:05
Some very accurate and neat work.
Its all going to look amazing under a paint layer.
Hope it continues well.
#1226 Posted : 14 September 2017 22:17:17
Thanks for looking in Tony.Cool Ah, the paint!LOL It's getting closer to that time when I can fire up the spray gun!BigGrin
Phil.
#1227 Posted : 15 September 2017 07:29:33
Excellent work as usual, you must dream about rivets..LOL
#1228 Posted : 15 September 2017 09:17:52
Thanks for looking in Mark!Cool More like nightmares about rivets!LOL All joking aside, it's one of those jobs that takes a lot of motivation to actually start, but once under way, it can be quite therapeutic.BigGrin
#1229 Posted : 15 September 2017 09:58:47
Glad to see you back on her PhilBigGrin more rivets too come hmmmLOL LOL regards PhilCool
#1230 Posted : 15 September 2017 10:24:28
Thanks for looking in Phil!Cool Yep, rivets, rivets everywhere!Blink LOL
daffy09
#1231 Posted : 15 September 2017 12:49:54
Great work Phil, that riveting is well worth all the effort you've put into her.
Happy building
David
#1232 Posted : 15 September 2017 13:03:08
Happy building
David
Hi David, thanks for looking in!Cool I must be ever so slightly bonkers!Blink To be honest, I can't wait to see the boat in undercoat, when hopefully all this work will pay off.
Phil.
#1233 Posted : 15 September 2017 16:11:56
Superb job with the riveting Phil Cool
#1234 Posted : 15 September 2017 16:40:59
Thanks for looking in and your encouraging comments Al!Cool BigGrin
#1235 Posted : 16 September 2017 09:33:52
Excellent work as always Phil and looking good. Hope you had a great holiday and have come back feeling refreshed and ready to go on the next zillion rivets! Blink ThumpUp
#1236 Posted : 16 September 2017 20:04:37
Thanks for looking in Kev.Cool. Bit of a slow start this week after my hols, now ready to crack on.
Phil W
#1237 Posted : 21 September 2017 23:07:52
This week's update continues with riveting the stern section of my U230 U-boat build log.
Before I could start the next section I first had to mark out where the stern draught marks were located.
Studying photographs and reading Dougie Martindale's article on the subject, I could mark out to the correct scale.
The 'zero' marker on these U-boats [Type VIIC's] worked on the system that it was 50 decimetres from the bottom of the keel [5 metres]. There were three sets down each side of the boat; two, port and starboard bow, two, mid-ships and two on each side of the stern.
The bow and mid-ships draught marks started at 'zero', with nine underneath and so on until it reached one. 'Zero' being 50 decimetres and nine, 49 decimetres etc.
The stern draught marks still had the 'zero' marker at 50 decimetres, but descended down to four and also ascended up from zero to four. This was to keep a close eye on the sea level as the stern sat very low to the water line.
I only used the number four once, on the ascending run, as i wouldn't have had enough to complete the mid-ships draught marks if i followed the pattern exactly.
The attached photo shows the port side draught mark locations beings marked on the stern with tape acting as a rule with 2mm intervals to indicate the number positions; the 1/48 scale equivalent to the 10cm spacings on the real U-boats.
#1238 Posted : 21 September 2017 23:08:52
The 'zero' fixed in place.
#1239 Posted : 21 September 2017 23:09:37
Port side draught marks completed on the stern.
#1240 Posted : 21 September 2017 23:10:59
Starboard side draught marks being marked out.
Guest (15)
This page was generated in 0.376 seconds.
