Another excellent update Jase  really like your work  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Another excellent update Jase  really like your work  regards Phil many thanks Phil “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Hi Jase. Nearly there now. I've found your diary and detailed descriptions of your techniques very helpful as I'm sure lots of us have. Loved your easy way to make a 'stay mouse' - that was a brilliant find, thanks for sharing that with us. Happy building David
Great tutorials Jase.  Excellent work. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
daffy09 wrote:Hi Jase. Nearly there now. I've found your diary and detailed descriptions of your techniques very helpful as I'm sure lots of us have. Loved your easy way to make a 'stay mouse' - that was a brilliant find, thanks for sharing that with us. Happy building David Many thanks Davis for the words of support greatly appreciated jason “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Sticky Wickett wrote:Great tutorials Jase.  Excellent work. Regards, Phil W. Thanks for looking in Phil last of the rigging pics up in the next day or so “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great rigging! Top work!Greetings, Walter
Nice work and a great tutorial, well done Jase!
Kev
ModelMania wrote:Nice work and a great tutorial, well done Jase!
Kev  Many thanks for looking in Kev Finish line in sight “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Good to see this build rapidly coming to its close, well done, will be a nice display item
Really brilliant work Jase  you make it look so simple  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
With the rigging completed we can now finish the ships boats.
The kit comes with two boats. I have chosen to display my model with just one boat stowed. if you wish to display both boats they are stacked one on top of the other. the second boat is built in the same manner as the first so will not be described hear.
The thwarts are cut to length and sanded to fit the curve of the boat edge to make a snug fit. It is best to not secure them in place until the boat has been fixed on the deck.
Before placing the boat items in place it is best to fix the boat to the main deck firs. The boats should be secured to the deck using four copper eyelets in the deck, painted matt black, and secured with two lengths of 0.5mm natural thread. However this is difficult to achieve as the ships boats are stowed up against the bulwark, it makes the process of securing the thread to the copper eyelets in the deck very difficult. This is my method of installing the boats to look authentic but with greater ease.
The kit comes with two boat chocks. In the instructions these are used on the port side and are visible on the deck, however I have fixed them to the ships hull on the starboard side so ultimately will be mostly hidden. attache the chocks with an even spacing then drill a hole in each chock through the side, not the end. a copper eye is then glued in place so that the 'eyes' face each other on the inside of the chocks one pointing astern one pointing towards the bow. attache a good length of the 0.5mm natural thread to each eye.
The boat can now be glued in place ensuring the threads are free, I clipped them over the side of the hull with a single peg. to ensure the boat sits flat I clamped the side of the boat to the bulwarks while the glue set.
If you are stowing both boats instal your thwarts and fix your second boat in place.
I chose to install the boats belongings before adding the thwarts as access is easier.
1. Rudder. the supplied rudder comes without a tiller arm. this can be simply created using some brass wire bent into shape. drill a hole through the rudder and glue the wire in place before painting the whole assembly white.
2. Grapple hook. The grapple is made of two parts and needs to be painted matt black, mine has been chemically blacked. yo can attache some natural thread to the eye of the grapple, if you do it should be cheesed, I chose to stow my rope separately to spread to the items.
3. Boat hooks. the two etched boat hooks should be removed and painted with a wood handle and black hook.
4. Oars. there are two sets of oars and they are different lengths. the 6 smaller ones are for the smaller boat. the oars should all be painted white with copper blades. once dry separate into two groups of 6 and tie them together with natural thread.
the grapple and rudder and rope were glued in place the thwarts then added before placing the boat hooks and oars. with this done two eye hooks painted black are added to the deck, drill holes and secure the hooks at an appropriate distance and secure the thread to the eye lashing the boat in place. the finish is authentic to how the boat would have been stowed, but easy to install.
jase attached the following image(s): “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
This has been a truly awesome adventure following this build jase..I love what you have done with her!! Brilliant !! Current Builds: Deagostini HMS Victory: Deagostini HMS Sovereign of the seas. Completed Builds: Del Prado: HMAS Bounty: Hachette: RMS Titanic: Del Prado: Cutty Sark...
Nicely done Jase, all looking good..... Regards Alan
Lovely work Jase, and an excellent diary Happy building David
Really enjoyed this tutorial build diary Jase  it`s a credit too you  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
many thanks everyone for taking the time to leave comments, it is greatly appreciated. Just one more post to go jase “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
Great work Jase and an excellent build log! Regards, Phil. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
