Parts list Options
Dave 71
#1 Posted : 11 September 2017 20:24:59
Hi, Got my Yamato full kit today and I noticed that there wasn't a parts list so you could double check that you have all the parts. There was an A4 sheet saying any parts missing to let them no but can't see how you can if there's not a list to check it against.
#2 Posted : 11 September 2017 21:16:20
Hi Dave
Have you downloaded all the instructions from the download page if not go to the link below and then click on the build tab to get them;-
http://www.model-space.c...-battleship-yamato.html
Once you have the PDF's downloaded you can check the parts stage by stage to make sure all is there. Also you should have some full size side [port and starboard] and deck plans with the kit.
There are other templates to download aswell like the hull templates and prop shafts, these should be printed off as a 1:1 to get the correct size.
You may also find you have two #8 frames that are the same in pack 1, the correct frame #7 will be included in the following pack. Frame #8 has locating lugs that fit into the hull base frame #7 has no lugs and is not as wide.
Dave 71
#3 Posted : 11 September 2017 22:45:29
Hi , thanks for info. I'm a bit old school I'm afraid, just thought there'd be some thing like a little hand book with a list of parts and tick box,s at the side .
#4 Posted : 11 September 2017 22:54:08
Hi Dave
Good luck with your build, hope to see a build log soon.
