10 Pages «<678910>
May's Dream Jag Options
#141 Posted : 23 August 2017 13:35:55
Nice to see you keeping busy May. Nice update.BigGrin
MFG
#142 Posted : 23 August 2017 14:06:38
Hi,
Thank you Mark, I do what I can BigGrin
May.
#143 Posted : 23 August 2017 14:28:04
Nice work May, I don't know about you but I like how this is coming together.
MFG
#144 Posted : 23 August 2017 14:43:28
Hi,
Thank you Al, well of course I have nothing to compare this build to having never done anything like this before, perhaps that's a good thing as I have an open view as they say...who knows, but even I can see how well the parts are made and go together, the gloss finish is so impressive I have a hard time taking pics at timesLOL and I'm enjoying watching her come together bit by bit each week!!!
May.
MFG
#145 Posted : 31 August 2017 16:01:44
Hi,
Issue 24
Subframe Part 6
This week we attach the right hand braces to the Subframe, I found it a bit easier to do steps 7 and 10 the "other way around" once the screw was in place for step 10 I then fixed the pin into place as seen in step 7 and then tightened the screw,
well it worked out well for me anyway BigGrin
See you next week,
May.
MFG attached the following image(s):
MFG
#146 Posted : 06 September 2017 16:48:03
Hi,
Issue 25
Subframe part 7
This week we attach the left hand braces which of course were fixed in the same way as last week so no problems there BigGrin
See you next week
May.
#147 Posted : 06 September 2017 20:12:53
Progressing well May BigGrin
#148 Posted : 06 September 2017 22:40:42
Looking good May, lovely progress....Cool Cool
MFG
#149 Posted : 07 September 2017 00:17:33
Hi,
Thank you gents, I can't believe we're a quarter of the way through the build already, doesn't time fly BigGrin
May.
#150 Posted : 07 September 2017 10:23:07
You`re making modeling look so easy now May BigGrin great updateBigGrin regards PhilCool
MFG
#151 Posted : 07 September 2017 12:11:38
Hi,
That's very kind of you to say Phil, I have the members of this forum to thank for my growing confidence and it's also testament to the designers of this build that a complete novice such as myself with zero experience can build it BigGrin
May.
MFG
#152 Posted : 07 September 2017 17:00:48
Hi,
So we're quarter of the way though the build and I thought it would be nice to take a photo of all of the "bits 'n' bobs" we've been supplied so far.
May.
MFG
#153 Posted : 13 September 2017 14:39:18
Hi,
Issue 26
Subframe part 8
This week we attach the Steering rack bracket and the left side lower brace. Both of these parts went on with little fuss. The right side lower bracket and the oil filter that are supplied aren't needed so these were labelled and stored away for later.
See you next week
May.
Metal Mech
#154 Posted : 13 September 2017 16:55:34
Looking good so far. This is that weird/interesting time when there is a lot of built stuff but nothing yet in the form of a car haha.
DeAgostini kit builds:
Shelby GT-500: 28% Complete
MFG
#155 Posted : 13 September 2017 17:41:52
Hi
Thank you for your comments, you're right I have a box full of goodies all waiting to go together......some day BigGrin
May.
#156 Posted : 13 September 2017 22:56:57
Looking good May.... You'll find when you start installing all the modules the car will grow very quickly, look forward to seeing that happen.....Cool Cool
MFG
#157 Posted : 13 September 2017 23:50:20
Hi,
Thank you Alan, I'm looking forward to that, even in "bits" you can see how good the finished model will beBigGrin
May.
MFG
#158 Posted : 20 September 2017 15:56:41
Hi,
Issue 27
Front Right Suspension
Lots of scary small parts to potentially lose this week OhMyGod and I had some problems along the way.
Firstly nether of the two supplied JP04 screws fitted into the receiving hole on the Caliper but the one that I had in my spare box fitted perfectly when I compared the three the supplied ones were slightly wider than my spare one.
Next up, the supplied JD06 screw just refused to screw into the top receiving hole of the suspension upright all the way leaving it very loose I then remembered a "trick" a learnt whilst building the DeLorean which is to unscrew the screw slightly and then re-screw it again. I carried on doing this until it had gone in deep enough and then swapped it out for the supplied spare one as the head was starting to wear.
My last problem was lining up the Pivot pin with the Shock Absorber, I daren't use tweezers as things have a habit of "pinging" out of them when I use them with small things and I was also very cautious about losing it, using my nails instead to hold it, it took me ages to get the position of the Shock Absorber right so that the pin would pass though, this was one of those moments when I wished for a third hand!!
All in all a far more challenging week for me than the last few issues but with a bit of perseverance and the occasional naughty word "here and there" I now have a very nice, working front suspension BigGrin
More of the same next week, hopefully things will go a bit smoother, thanks for dropping in,
May.
#159 Posted : 20 September 2017 16:05:08
Really starting to come together now MayBigGrin top jobThumpUp regards PhilCool
MFG
#160 Posted : 20 September 2017 16:08:28
Hi,
Thank you Phil, she was a bit awkward this week but she's certainly starting to take shape BigGrin
May.
10 Pages «<678910>
This page was generated in 0.259 seconds.
