Ok folks, so here is my build diary for my attempt to build a radio controlled replica of a Russian T72 tank. I haven't decided yet if i will just follow the build as per the instructions, or 'try' to attempt a bit of customization like the other build logs on this forum. I should warn you that i am not adverse to a bit of plagiarism where i feel it necessary and it's something i feel i can actually accomplish with my limited experience (and let's face it there are some excellent build ideas on this topic!). Please feel free to pass comment on my build, whether it be to advise or criticise, and any suggestions gratefully received! Here are my before and after shots of Pack 1, stages 1 to 5. The reason the rear container is not fitted is because i managed to lose the screw! thankfully CS has come to my rescue and is sending out a replacement. Thanks for looking Gray CaptnBirdseye attached the following image(s):
Good to see another T-72 underway
Nice start Graham, hope you have fun building this and well done for starting a build diary.
I wouldn't worry about plagiarism, the whole point of posting builds of the same model is to share experiences with others and to hopefully help each other with ideas - if people don't want their ideas copied then they shouldn't share them, lol!
Kev
Great to see Gray, good luck with the build. Following your progress all the way..... Regards Alan
Great start Gray  you will love it  will be following  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Thanks for looking guys, and appreciate the positive comments. Regards Gray CaptnBirdseye attached the following image(s):
Great to see this up and away  will this be a straight build or are you going to do a bit of weathering  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Great to see this up and away  will this be a straight build or are you going to do a bit of weathering  regards Phil Hi Phil Thanks for looking and the comments  i actually fancy having a go at the water transfer process, it looks easier than airbrushing, but will have to see how it goes. Regards Gray
