 Hi Firstly welcome to the forum and enjoy your build. Go ahead and stain your deck then use a matt varnish to seal it, the deck furniture will fix to this surface when you get to placing it. See explanation below:- A matt varnish gives a finish like sandpaper that will not reflect light so well with troughs and ridges that break up the light reflection giving that dull look this gives any glue used a grab to adhere too. Gloss varnish gives a smooth finish that reflects light well and has no grab as it is smooth. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Beginner Level 3   Groups: Registered
Joined: 03/09/2017 Posts: 26 Points: 102 Location: Canada
Thank you for your reply I was worried that it would be difficult to glue the deck furniture over the varnish. Would you need to use CA glue? Completed Build: Bluenose
Current build: Pegasus
Welcome to the forum. I look forward to seeing your build of the "Bluenose" As for posting pictures the link below should help. Posting PicturesHappy Building Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Welcome aboard, look forward to seeing your build come together.....  .. If it's help you need then you are certainly in the right place, lots of experienced ship builders here ready to assist.... Regards Alan
Gandale wrote:Welcome aboard, look forward to seeing your build come together.....  .. If it's help you need then you are certainly in the right place, lots of experienced ship builders here ready to assist.... Regards Alan Thank you Alan Completed Build: Bluenose
delboy271155 wrote:Welcome to the forum. I look forward to seeing your build of the "Bluenose" As for posting pictures the link below should help. Posting PicturesHappy Building Regards delboy271155 (Derek) Thank you Derek Completed Build: Bluenose
 Hi I would use a medium or gel type super glue applied with a tooth pick or such like Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
