Gun Ports on Second Level Options
Atholm
#1 Posted : 16 April 2011 16:36:16
Hi Shipmates
I have a problem with the gun ports on level 2 between frames 14 and 16.
The instruction 3 of issue 27 "Then redraw the line nearest to frame 15, moving it 2mm forward of the line you first marked." This line is 4,5mm aft of frame 15.
This this correct. To me if the instruction referred to frame 14 not 15 the gun ports would be more symmetrical.Confused
ThanksBigGrin
Athol
Son of Bulwark
#2 Posted : 16 April 2011 17:34:04
Hi Atholm! Cool
I instruction are correct move the line at frame 15 from 4.5mm away from the rib to 2.5mm away from rib 15 the reason is an anchor hangs in that area and would cover the gun port at frame 14 if it wasn't 4.5mm away from rib 14 it's the drawing that's incorrect.
Atholm
#3 Posted : 16 April 2011 17:53:10
Hi Son of Bulwark
Thanks for your reply. It now makes sense.
The instruction at frame 14 is to move it 4,5mm away to the stern.
Happy building.
Athol
This page was generated in 0.122 seconds.
