Nice to see you keeping busy May. Nice update. Mark Regards Markwarren (Mark) Admin
 Rank: Pro  Groups: Registered
Joined: 27/02/2017 Posts: 410 Points: 1,220 Location: Lancashire
Markwarren wrote:Nice to see you keeping busy May. Nice update. Mark Hi, Thank you Mark, I do what I can May.
Nice work May, I don't know about you but I like how this is coming together.
Spal wrote:Nice work May, I don't know about you but I like how this is coming together.
Al Hi, Thank you Al, well of course I have nothing to compare this build to having never done anything like this before, perhaps that's a good thing as I have an open view as they say...who knows, but even I can see how well the parts are made and go together, the gloss finish is so impressive I have a hard time taking pics at times  and I'm enjoying watching her come together bit by bit each week!!! May.
Hi, Issue 24Subframe Part 6 This week we attach the right hand braces to the Subframe, I found it a bit easier to do steps 7 and 10 the "other way around" once the screw was in place for step 10 I then fixed the pin into place as seen in step 7 and then tightened the screw, well it worked out well for me anyway See you next week, May. MFG attached the following image(s):
Hi, Issue 25Subframe part 7 This week we attach the left hand braces which of course were fixed in the same way as last week so no problems there See you next week May. MFG attached the following image(s):
Progressing well May Al
Looking good May, lovely progress.... Regards Alan
Spal wrote:Progressing well May Al Gandale wrote:Looking good May, lovely progress.... Regards Alan Hi, Thank you gents, I can't believe we're a quarter of the way through the build already, doesn't time fly  May.
You`re making modeling look so easy now May  great update  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:You`re making modeling look so easy now May  great update  regards Phil Hi, That's very kind of you to say Phil, I have the members of this forum to thank for my growing confidence and it's also testament to the designers of this build that a complete novice such as myself with zero experience can build it May.
Hi, So we're quarter of the way though the build and I thought it would be nice to take a photo of all of the "bits 'n' bobs" we've been supplied so far. May. MFG attached the following image(s):
Hi, Issue 26Subframe part 8 This week we attach the Steering rack bracket and the left side lower brace. Both of these parts went on with little fuss. The right side lower bracket and the oil filter that are supplied aren't needed so these were labelled and stored away for later. See you next week May. MFG attached the following image(s):
Joined: 07/07/2015 Posts: 1,292 Points: 3,928 Location: Allentown PA
Looking good so far. This is that weird/interesting time when there is a lot of built stuff but nothing yet in the form of a car haha. DeAgostini kit builds:
Millennium Falcon: 18% Complete Shelby GT-500: 28% Complete Thunderbird 2: 13.75% Complete
Metal Mech wrote:Looking good so far. This is that weird/interesting time when there is a lot of built stuff but nothing yet in the form of a car haha. Hi Thank you for your comments, you're right I have a box full of goodies all waiting to go together......some day May.
Looking good May.... You'll find when you start installing all the modules the car will grow very quickly, look forward to seeing that happen..... Regards Alan
Gandale wrote:Looking good May.... You'll find when you start installing all the modules the car will grow very quickly, look forward to seeing that happen..... Regards Alan Hi, Thank you Alan, I'm looking forward to that, even in "bits" you can see how good the finished model will be May.
Hi, Issue 27Front Right Suspension Lots of scary small parts to potentially lose this week  and I had some problems along the way. Firstly nether of the two supplied JP04 screws fitted into the receiving hole on the Caliper but the one that I had in my spare box fitted perfectly when I compared the three the supplied ones were slightly wider than my spare one. Next up, the supplied JD06 screw just refused to screw into the top receiving hole of the suspension upright all the way leaving it very loose I then remembered a "trick" a learnt whilst building the DeLorean which is to unscrew the screw slightly and then re-screw it again. I carried on doing this until it had gone in deep enough and then swapped it out for the supplied spare one as the head was starting to wear. My last problem was lining up the Pivot pin with the Shock Absorber, I daren't use tweezers as things have a habit of "pinging" out of them when I use them with small things and I was also very cautious about losing it, using my nails instead to hold it, it took me ages to get the position of the Shock Absorber right so that the pin would pass though, this was one of those moments when I wished for a third hand!! All in all a far more challenging week for me than the last few issues but with a bit of perseverance and the occasional naughty word "here and there" I now have a very nice, working front suspension More of the same next week, hopefully things will go a bit smoother, thanks for dropping in, May. MFG attached the following image(s):
Really starting to come together now May  top job  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
tigerace wrote:Really starting to come together now May  top job  regards Phil Hi, Thank you Phil, she was a bit awkward this week but she's certainly starting to take shape May.
