Thunderbird 2 pods Options
Tony H
#1 Posted : 30 August 2017 11:08:24
Rank: Amateur Level 1
Good morning all. A quick question for you. Does anyone know which font was originally used for the pod door numbers? It's just that pod 3 doesn't have a laboratory in it, that was pod 5, as in Pit of Peril. For accuracy,the easy way is to leave the lab out of the pod but if there is a way of replacing the number on the doors then I would seriously consider that. Thanks in advance for your help.
Started Thunderbird 2!
#2 Posted : 30 August 2017 11:31:43
You could do a google search on "Thunderbirds Font".
That seems to bring up a whole load of links you could look at
https://www.google.co.uk...en-gb&client=safari
Tony H
#3 Posted : 31 August 2017 12:54:55
Thanks Tony. I found exactly what I need but for some reason I can't see the downloaded file. Could be because I am using a tablet at the moment.
#4 Posted : 31 August 2017 15:27:28
If you have Microsoft word there is a font you can install for Thunderbirds
