7 Pages <1234>»
andre's MP 4/4 build Options
monzaandre
#21 Posted : 25 August 2017 02:27:26
the carbon tub for the driver compartment was also a bit of a head ache. it is not woven carbon but rather a rough surface. I had some carbon paper flying around at home (from my rc model plane days). I "molded" this into the cockpit with clear lacquer. it took about 10 layers of this stuff proved to be very porous.
monzaandre attached the following image(s):
monzaandre
#22 Posted : 25 August 2017 02:29:19
the small "mishap" in the carbon part in the top left corner has been fixed ;)
monzaandre
#23 Posted : 25 August 2017 02:31:04
front suspension assembly. I replaced all the Phillips head screws with HEX stainless steel bolts.
monzaandre
#24 Posted : 25 August 2017 06:24:53
#25 Posted : 25 August 2017 08:42:16
Somehow I missed the start of your diary Andre, but some fabulous improvements going on here, like your interpretation of the rough surface in the cockpit tub amongst other details - very well done! Drool Cool ThumpUp
I'm building an MP4/4 myself in the much smaller 1:20 scale with the 'Top Studio' Superdetail set. You can find it here if you're interested?:
http://forum.model-space...amp;m=252765#post252765
Keep up the good work, I'll be watching. ThumpUp
#26 Posted : 25 August 2017 11:57:18
Another finely detailed Mp4/4 coming together Cool nice work.
monzaandre
#27 Posted : 25 August 2017 12:45:12
Many thanks for all the kind encouragement.
Kev, shall follow your build. thanks a lot for the link mate.
Next up I didnt quite like the engine mounting plates. the molded in nuts are ok but they dont really represent the studs with nuts as per the original. So I drilled out all the dummy screws and fabricated the studs/nuts as per the next picture
monzaandre
#28 Posted : 25 August 2017 12:50:01
monzaandre
#29 Posted : 25 August 2017 12:54:03
These are "ugly" phillips heads cut off and then just added a m1 nut....
monzaandre
#30 Posted : 25 August 2017 13:01:29
Now started to work on the engine. I am not building this in the suggested sequence and again, I wont show too many pictures of the standard steps but rather share the small mods and how the will then look like installed.
I did find that the fuel injector plastic parts had some rather strange impressions in the imposed nuts so I added some stainless steel hex nuts. they are a touch too small but I think they will still look better than just the plane plastic parts. some repainting will also be needed.
monzaandre
#31 Posted : 25 August 2017 13:06:11
monzaandre
#32 Posted : 25 August 2017 13:10:15
along the way a bit of detail to some of the wiring and piping
monzaandre
#33 Posted : 29 August 2017 13:04:32
while doing some engine assembly I found that the heat exchange was very nicely finished but had rather unsightly gaps after gluing the parts. I was playing with my kids today and suddenly I had an idea.... i wanted to try and create alu welding pattern with Plasticine ..... here is how this turned out ....
monzaandre
#34 Posted : 29 August 2017 13:10:44
Lets hope the plasticine will harden with the paint and remain sticky enough
#35 Posted : 30 August 2017 12:09:46
Some great details there !! ThumpUp
#36 Posted : 30 August 2017 14:30:43
Yes indeed very nice work Andre, I like your weld beads, they turned rather well didn't they? Cool ThumpUp
#37 Posted : 30 August 2017 16:31:23
Another interesting update Andre BigGrin nice idea for the welding.
#38 Posted : 30 August 2017 16:41:33
Fantastic attention to detail, well done Cool
#39 Posted : 30 August 2017 19:40:58
BigGrin Nicely doneCool
#40 Posted : 30 August 2017 21:40:46
Looks fab, another great update....Cool Cool
7 Pages <1234>»
This page was generated in 0.250 seconds.
