106 Pages «<5758596061>»
#1161 Posted : 24 August 2017 23:25:54
That does look very time consuming, another great update.BigGrin
#1162 Posted : 24 August 2017 23:44:17
Thanks for looking in Mark!Cool Yes it is time consumingCrying but they really change the look of the U-boat by breaking up the surface.
Phil.
#1163 Posted : 25 August 2017 08:11:03
It really adds to the realism PhilBigGrin it looks outstandingDrool regards PhilCool
#1164 Posted : 25 August 2017 08:17:06
More excellent work from you Phil, looking great! Enjoy your holiday, I think you're going to need it after all of those rivets! Blink Blink ThumpUp
#1165 Posted : 25 August 2017 08:39:47
Phil
You have put this model at the top of its class.
It looks wonderfulmit really does.
#1166 Posted : 25 August 2017 09:07:19
Thanks very much Phil!Cool It's a slow job but worth it.BigGrin
#1167 Posted : 25 August 2017 09:10:11
BigGrin Thanks Kev for your comments!Cool Yep, can't wait for a week away, but I will still probably dream of rivets.LOL
#1168 Posted : 25 August 2017 09:11:32
birdaj2 wrote:
Phil
Thank you Tony for your encouraging comments!Cool
#1169 Posted : 25 August 2017 22:50:59
Top class work Phil, she has all the makings of being a fantastic build.... very well done....Drool Drool
#1170 Posted : 29 August 2017 09:05:08
Thank you Alan for your encouraging comments.Cool Always appreciated!
#1171 Posted : 31 August 2017 22:10:34
On this weeks update of my U230 U-boat build log I will be continuing with riveting the bow section and starting the stern section.
The attached photo shows further rivets added to the lower starboard bow section.
#1172 Posted : 31 August 2017 22:13:39
This photo shows one of many weld lines in place. I'm happy with the scale of these weld lines compared to the part-works brass etch which looked slightly over size.
#1173 Posted : 31 August 2017 22:14:16
Continuing aft along the lower starboard side.
#1174 Posted : 31 August 2017 22:15:33
In this photo, you can see how the rivets taper off ending this particular section.
#1175 Posted : 31 August 2017 22:16:11
Looking forward along the lower starboard side.
#1176 Posted : 31 August 2017 22:17:14
Continuing adding rivets along the lower port side.
#1177 Posted : 31 August 2017 22:18:15
Moving aft.
#1178 Posted : 31 August 2017 22:19:33
Moving further aft showing the weld lines that form the profiled shape of the port forward hull.
#1179 Posted : 31 August 2017 22:21:39
In this photo the rivets taper off, in the same way as the starboard side, marking the end of this particular section on the lower port hull.
#1180 Posted : 31 August 2017 22:22:24
Looking forward along the lower port hull.
Guest (15)
This page was generated in 0.528 seconds.
