13 Pages «<89101112>»
Panart 1/16 Victory Sloop Build Options
#181 Posted : 24 August 2017 18:30:47
Very nice work Alan, beautifully neat and tidy, well done. Cool ThumpUp
#182 Posted : 25 August 2017 23:19:01
Thanks again to everyone who took the time to look in and comment, very much appreciated...Cool Cool
Moved the build forward again and this actually turned out to be quite a time consuming build session. Constructed another of the ships accessories, the ships approach hook. Simply a length of 4mm dowel, tapered down to 2.5mm at the end of the shaft. The other end had to be shaped to accommodate the hook itself and once done was give a couple of coats of matt varnish....Cool Cool
Next, I installed the benches from lengths of 4 x 15mm walnut, the rear benches were shaped from 4 x 20mm walnut strips. Once happy these were glued into place. The support brackets were the most time consuming part, these were individually cut and shaped for their respective positions, all from 2 x 15mm walnut. It was slow going....Cool Cool
Moved onto a heart stopping part of the build, the drilling of 10mm holes in the centre area of the decking to accommodate the 2 columns for the capstan ropes. The ropes from the capstan go down through the centre of the columns and come out of the bottom of the hull and run along to the stern area. These ropes were used when setting or recovering the Victory's anchors. An illustration on this has been posted here:
http://forum.model-space...amp;m=253045#post253045
The heart stopping moment came when drilling holes out through the bottom of the hull itself, I was concerned about splitting or splintering the hull. Happy to say it all worked out just nicely....Cool Cool
Last part of this build session was to fit the corner supports at the stern and the bow support. Everything was then given 2 coats of matt varnish.....
Next task is some more accessory items and the making up of the capstan/winch systems so until then, happy modelling all.....Cool Cool
daffy09
#183 Posted : 25 August 2017 23:56:32
Beautiful work Alan, the detail on this build is superb. Also found the link to show how the anchor retrieval was carried out to be very informative. I for one had never realised how important these launchs were. I bought two or three books on the Victory while I was building her, but I don't recall any of them detailing this use for the launch. Very good piece of info.
Happy building
David
#184 Posted : 26 August 2017 02:48:29
Tremendous work Alan. Your doing an excellent job on the sloop.
Chris Cool
#185 Posted : 26 August 2017 07:48:56
The accuracy and attention to detail looks astounding, well done Alan Cool
#186 Posted : 26 August 2017 08:16:08
BigGrin Top work as always AlanCool
z8000783
#187 Posted : 26 August 2017 08:22:34
Groups: Unapproved
Well done Alan, nice work.
#188 Posted : 26 August 2017 10:29:40
Beautiful, stunning and definitely museum quality, you should be very proud of your work Alan!!
Very well done, that's impressive!! Drool Drool ThumpUp
#189 Posted : 26 August 2017 17:56:48
Superb craftsmanship Alan Cool
#190 Posted : 26 August 2017 20:45:26
Beautiful work Alan, real craftsmanship at work.
#191 Posted : 26 August 2017 23:28:06
Thanks guys, appreciate all the comments made.... More to come soon....Cool Cool
#192 Posted : 01 September 2017 22:50:37
Part of the reason I'm enjoying this build so much is the fact that a great deal of the parts need to be fabricated from scratch and that includes the parts needed to make up the stern gantry. From the plans, I started by tracing the main gantry parts onto greaseproof paper, these outlines were then transferred onto 3.5 x 17mm limewood strips. Then it was a case of cutting and sanding down until I had the correct profile shapes. Once happy, marked out and drilled the holes to take 2mm dowels and 2mm brass rods. The marking out of these holes had to be done with care to ensure the gantry went together without straining any of the joints and that it sat square when finally fitted to the launch. Some of the brass rods required one end to be flattened out, this was done using a small anvil and hammer.
Also needed to cut a small length of 10mm dowel, drill a 2mm hole through the centre lengthways, first drilling from one end and then drilling from the other, this ensured the holes at either end were in the correct place and not offset. The dowel then had to be flattened on one side to match the profile of the stern transom and the tops of the gantry legs.
A dry assembly was then carried out to make sure everything went together the way it should and test fitted to the stern of the launch. Once happy I then glued the assembly together and left to dry. Next stage was to cut the ends of the brass rods and 2mm dowel, fine sand everything down before applying 2 coats of matt varnish. Now leaving to dry fully before assembling on the launch, this will be shown on the next update. All in all this was a fun assembly to do so until the next update, happy modelling....
Cheers
#193 Posted : 02 September 2017 07:25:02
Beautiful work AlanBigGrin looks superbDrool regards PhilCool
z8000783
#194 Posted : 02 September 2017 07:48:10
Groups: Unapproved
Beautiful work, Alan.
#195 Posted : 02 September 2017 10:21:28
Lovely work Alan Cool
daffy09
#196 Posted : 02 September 2017 13:02:25
Hi Alan,
you're doing a superb job with the launch and that looks like a complicated bit of assembly work there considering you had to scratch build it.
I often wondered what purpose this part of the launch served until you enlightened us in your previous post. Well done.
Happy building
David
#197 Posted : 02 September 2017 16:47:56
Cracking piece of work Alan, looks superb.
#198 Posted : 02 September 2017 18:56:16
Looks like a real builders model and you`re doing a cracking job on it.
Cool Cool Cool Cool Cool
#199 Posted : 02 September 2017 19:26:14
BigGrin Great work Alan and just the sort of kit I relish getting my teeth intoCool
#200 Posted : 02 September 2017 21:00:03
Top job Alan, a pleasure to see work of such high standard, very well done! Cool Drool ThumpUp
This page was generated in 0.200 seconds.
