Joined: 31/08/2011 Posts: 629 Points: 1,963 Location: Plymouth
Gandale wrote:Another nice update Chris, Robi's certainly growing..... Regards Alan Thank you Alan.  Much appreciated! Thanks for looking in! Chris
Spal wrote:Looking good Chris Al  Thank you Al! Chris.
stevegbr wrote:looks very interesting your build, how are finding it? Hi Steve. It has been a VERY difficult build at times...as I have completed one whole arm...just to find that the servo in the elbow joint is not working and I have had to strip down 2 hours work and start again!! I had the same problem with one of the legs and the neck servo where Robi tilts his head forward. Many many hours have gone into this...and I am a very patient person, but the frustration built up at times, but it is surprising how much patience you have when you don't think you have the resolve. I am nearly on the home straight now...so I feel it has all been worth it!! Thanks for looking in!! Chris.
 Rank: Pro Groups: New Members, Unapproved Joined: 24/08/2009 Posts: 48,827 Points: -13,348
schueyking wrote:stevegbr wrote:looks very interesting your build, how are finding it? Hi Steve. It has been VERY difficult build at times...as I have completed one whole arm...just to find that the servo in the elbow joint is not working and I have had to strip down 2 hours work and start again!! I had the same problem with one of the legs and the neck servo where Robi tilts his head forward. Many many hours have gone into this...and I am a very patient person, but the frustration built up at times, but it is surprising how much patience you have when you don't think you have the resolve. I am nearly on the home straight now...so I feel it has all been worth it!! Thanks for looking in!! Chris. hi chris reason i asked is because i have just subscribed to this and wondered is it hard or easy, you have answered my question, got the first two parts coming soon, i will follow your build with interest. keep up the good work.
Good to see this coming along
Be mindful of how the wires are routed as a few builders have found them pulling loose from the end socket as a result of becoming taught during his movemnent cycle.
Tomick wrote:Good to see this coming along
Be mindful of how the wires are routed as a few builders have found them pulling loose from the end socket as a result of becoming taught during his movemnent cycle. Hi Tomick I have found this out already! I twisted the head around more than 90 degrees...and forgot if I turned Robi's head left or right...so I twisted 360 degrees. The result was a non functioning neck servo When I took the neck off again..they were all twisted around each other!! I reset the connectors...and now everything seems fine. Fingers crossed!! Thanks for looking in!! Chris.
He's coming along a treat now Chris, nice work.
looking very good chris, you are nearly at the end, bet you cant wait.
Getting near that finishing point Chris, Robi is looking good.
Looking good Chris, not far to go. Mark Regards Markwarren (Mark) Admin
Thanks guys!! I had a little wobble with the full body test. Robi's Neck and Hip Servo were not moving...so I checked the back Servo and everything seemed ok,  but I reconnected the two servo cables again anyway...and hey presto, everything is now working fine!! I am not sure what I did...but it was on a wing and a prayer Everything works great now!!! Thanks for loooking in guys,very much appreciated!! Chris.
