 Rank: Beginner Level 1 Groups: Registered
Joined: 22/08/2017 Posts: 9 Points: 33 Location: Jersey, Channel Islands
I have been trying for a couple of hours now, but the foot casing I got in Issue 31 doesn't fit the leg!
have I been sent the wrong part?
Hi Is there any chance of sending me a picture of the part in question to ascertain what the problem may be? Regards Mark Regards Markwarren (Mark) Admin
please see attached picture
I have checked your parts with mine, and they are exactly the same. Please refer to the official build diary, and see if that helps. http://forum.model-space...spx?g=posts&t=23476
Let me know how you get on Regards Mark Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Hi, the parts look correct to me. Have you checked out the official video build at https://www.youtube.com/...phYZW9OUKndCE_wekwtnEGN
to compare yours. Otherwise would really need to see a pic of the casing in relation to the leg to try and ascertain what the problem might be. Graeme
well it's not fitting for me and I have checked the video see the attached picture
The 4 lugs fit into the metal frame. Please see picture Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
if I line up the lugs this is what happens (in picture)
Can you send me a picture of the leg piece without the foot in place please Mark Regards Markwarren (Mark) Admin
there are part numbers inside the casings LPR-34 & LPR-36, I wonder if I have been sent the other legs casings
you have the correct parts, same as mine. Does the leg look like this, looking at the bottom section? Regards Markwarren (Mark) Admin
I think so, look at my picture
Okay, that looks the same too. When you fit the foot piece in place, is it the bottom section of the let that doesn't clip in? Regards Markwarren (Mark) Admin
Correct and the clip area is off to the side
Can you unscrew the metal plate off and see whether that could be the problem (LFR 10) and see if it can align differently? Looking at your picture, the plate seems to be to the right more, rather than the left. If you look at my picture you will see what I mean. Regards Markwarren (Mark) Admin
Hi Having looked at your pictures more closely, the metal support plate is sitting too far to the right. It maybe that you have installed the mounting plate the wrong way round in issue 21, this would push the support plate too far to the right. Let me know how you get on Regards Mark Regards Markwarren (Mark) Admin
I had part LFR-05 located on the wrong side of the leg strut, I have swapped it all around and everything is good, thanks for the help
Glad to here it is all sorted. Mark Regards Markwarren (Mark) Admin
