I have printed the 1:1 scale diagrams for both the bow and stern plates, but things dont seem to be right. This is what think the stern should be.   I'm sure i have bow parts missing ( 2 plates and the 2 small wooden rods ) because this is what i have left from the bow/stern packs.  Any help would be appreciated.
ok, i can fix the stern myself, but i need parts 1,2,3 and the 2 pegs for the bow as they werent delivered with the rest.
Any chance they can be sent, please?
Hate to tell you but the parts you show in photos 1 and 2 which you say are stern parts are actually the bow parts, and in your last photo you show a mix of bow and stern parts - The four small triangle parts are bow, as is the large open 'U' shape, and also the bottom two closed 'U' shapes.
The bow block should be 15 parts tall, yours counts 14.
Have a look at the photos in section 1 of my Yamato diary build, in particular post #11 which shows the stern block parts, and post #13 which shows the bow block parts, and how both should look.
i have looked at your post tomick, i also have printed the 1:1 diagrams supplied and when i compared what i have to the diagram nearly all are slightly too long to fit the diagram. I realise that might happen but it doesnt change the fact that i am missing at least 5 pieces from the stern ( Yes, i mixed up bow and stern  ). I will go back and spend the night comparing my stuff to yours and see what happens though  .
If you are missing parts you need to contact Admin directly rather than just posting a note withing your diary build which is likely to get missed.
thanks for the info, would have sat here for ever waiting
