2 Pages <12
Mclaren tools Options
Dontshootme
#21 Posted : 08 April 2011 09:27:58
Tomick wrote:
You could try the Stanley 'FatMax' 00 Phillips
Excellent tool,my hands are the size of steam shovels & arthritic,I have no trouble at all holding it http://cgi.ebay.co.uk/ws/eBayIS...em&item=180457147246
hil26
#22 Posted : 13 April 2011 13:34:08
Rank: Amateur level 2
got the wera phillips 00 of ebay and the end has rounded !!!!!!
Got to be a copy - but to send back will cost more in postage!!!! and postage is not refundable.
Dave
saintsman123
#23 Posted : 13 April 2011 14:18:48
Don't always go for e-bay Hil, there are cheaper places out there, eg
I needed a razor saw for Victory, there was a Draper set incuding blades mitre block and sanding block on e-bay for £29-£30. Amazon had the same set for £14.99, and quite a few others on Amazon for around £20/£22.
BTW Tomick mentioned a Stanley screwdriver, as he's the expert I would go with his recommendation.
Come on you Jimmies
scotty2hotty
#24 Posted : 24 June 2011 19:08:00
hi guys. where can i get more of the sandpaper and what grade was it again
cheers
scottww86
#25 Posted : 24 June 2011 19:17:31
i bought a size 0 phillips screwdriver from halfords. its the professional range so guaranteed for life!! no problems so far and it was only £3.50!!
Austin
#26 Posted : 24 June 2011 21:28:29
If you have a hobby craft near you try them. I bought a set of draper screwdrivers which have about 10 drivers in it and some tweezers, it was about £6, bargain. And they work a treat.
#27 Posted : 24 June 2011 21:46:08
Hi guys remember Mr T said buy the best screw driver you can afford.
We are going to spend nearly £700 on a fantastic model, I think we need to spend a little extra to get the best screw drivers to do the job, remember its the only tool we need, I spent £22 and they will not let me down, more to the point the McLaren will benefit big styleLOL
scotty2hotty
#28 Posted : 24 June 2011 21:59:41
and the sandpaper?
scotty2hotty
#29 Posted : 24 June 2011 22:06:54
how many different sized screw heads will there be?
#30 Posted : 24 June 2011 22:11:53
Hi Scotty,
I did not use the sandpaper, I use ladies manicure files they are not expensive ( 35p for 6 )Side1 is med side 2 is fine you can cut it and glue small pieces on to bits of planking hope that helps.LOL
Screw heads 2/3
David rozee
#31 Posted : 25 June 2011 14:19:03
i bought a screw driver set from maplins today 12 piece presion set for 5.99 much better than the screw driver that came from the first issue
Austin
#32 Posted : 03 July 2011 11:02:54
Those White gloves are creeping me out dude.Laugh
mental73
#33 Posted : 06 July 2011 10:50:53
i have been dipping the tips of the screws in vaseline to help with screwing them in. seems to have worked well so far.BigGrin
2 Pages <12
This page was generated in 0.284 seconds.
