Rib Numbers Options
Glen
#1 Posted : 12 April 2011 14:39:50
Hi all
I'm just starting to fit the keel and beakhead, and the mag says to run the first part of the keel from frames 16-24, but this is the problem, i have lost the numbers of the frames due to planking.
Can anyone count the frame numbers from the foward bulkhead along to the stern for me please, my memory has gone and i can't remember what number of the first frame was.
Thanks,
GlenConfused
Roger the Cabin Boy
#2 Posted : 12 April 2011 15:23:19
Frame #12 as arrowed in the photo below, but be careful not to count from the two #7 frame parts just forward of frame 12
Glen
#3 Posted : 12 April 2011 15:26:13
Thanks Tomick nice one.
Roger the Cabin Boy
saintsman123
#4 Posted : 12 April 2011 16:37:33
Glen
I had this problem, as well look in the mags, can't remember which issue but you can work out the frame numbers from here. Laterly ( I should have done it earlier) I marked the very top of the frames with the numbers, as I kept forgetting, in fact at one time I was counting the frames the wrong way round. You could always try a bit of masking tape with the numbers on taped around the rib tops, as numbering becomes very important when planking the decks, the mags even tell you to mark the deck supports to make sure positioning is perfect.
Come on you Jimmies
Glen
#5 Posted : 12 April 2011 18:26:55
Thanks for that mate,done just as you said marked the top of the frames.
Roger the Cabin Boy
This page was generated in 0.101 seconds.
